First post, by BitWrangler
Hi folks,
In the junk drawer I noticed I had a couple of dead laser pointers, the generic keyring, cat distractor type. Guess the diodes burn out in the cheapies. What use are they I thinks... I know, CMOS batteries! just unscrew the head and solder on leads (bypassing button switch) and you've got a 4.5V worth of lithium cells holder. There's also a slightly shallower version of the batteries they take that might give you 6V if you stick 4 of them in. How long will they last? Dunno, probably not the 15 years of those square pack lithium cells, more like cheapie CR2032s probably. Posting this before I forget it, meaning to try it on the next board I find that needs one. They would probably mount to a case nicely with a cable clamp, or ferrite rod antenna holder, or just ziptie them somewhere.
Reply 1 of 3, by mkarcher
BitWrangler wrote on 2021-07-30, 02:16:
The laser pointers usually use LR44/AG13 coin cell batteries, which are alkaline, not lithium. There is the SR44/SG13 silver oxide type, too, which has around twice the capacity and a lower internal resistance, but that type is too expensive for the cheap laser pointers. I never saw a lithium cell in that case format, though.
Reply 2 of 3, by BitWrangler
They are? Wow that's a heck of a thing to miss for years, thinking all button and coin cells are lithium 🤣
Reply 3 of 3, by dormcat
BitWrangler wrote on 2021-07-30, 12:09:
Take a glance on vintage camera communities, particularly on providing power for cadmium sulfide light meters. 😉
Side note: IMHO film photography has a lot in common with retro computing.
