First post, by bigmandan
Hello everybody, i've had this sound card in my other pc, which was socket 1 and it worked just fine. However, in my current setup (amd k6 266, 128mb ram, quantum fireball 6gb, s3 virge 4mb (added ram with chips) , acorp 5tx29), it just shows code 9 error message. sometimes i can see that device appeared in sound device options, but after reboot i still get the same message. if anyone knows how to deal woth that ot would be very appreciated.
p.s soundblaster emulation in most games works just fine even without drivers
Reply 1 of 2, by pc-sound-legacy
I would recommend to look at the jumper settings to get the correct IRQ/DMA/adress settings. Then go into bios and reserve this IRQ to legacy ISA. In BIOS, set resource configuration to auto /by BIOS, NOT let it controll by PNP OS. (You can't trust windows 9x to controll resources) Install the driver and set the values manually.
Reply 2 of 2, by Jo22
ES688 has a jumper for selecting SB2.0 and SB Pro 2 mode..
Maybe the driver expects the latter, not sure.
