caesar wrote on 2021-08-03, 09:38:Hi All, […]
Hi All,
I was hoping someone could help me identify this motherboard as I need to find out the jumper configs. Not sure if it works but I have a 486dx50 that I could stick in it.
The only marking on the board are LILI429-v1.2
Thanks in advance.
The DX50 should work without issues on that board, it's a 5V chip. Worst case, it'll run at a lower speed (make sure it's in the right orientation, watch the corner).
You will also need 2 more sticks of RAM, preferably the same size as the one you have on the board (or replace them with other 4 identical sized sticks).
As for identifying the board, it will be very useful if you could dump the BIOS (or make a photo of the boot screen, so I can read the post string).
Let me know if you succeeded.
