First post, by schultzd
Thanks for help on config.sys question.
I finally got the first linkage program to work. However, there seems to be a problem. I got the program to work after the input file was transferred to dos in windows 98 and after using the edit command to view and edit the input file. The input file is generated by saving an excel file as a tab delimited file. However, no matter what program I use (world text, simple text, notepad, wordpad), they all leave an extra return or something such that when the file is viewed with the edit command in dos there is an extra line at the bottom, which must be removed for this dos linkage program to work. There doesn't appear to be an "edit" program/command/whatever, in dosbox. Is there some other program out there that can strip clean these input files before I transfer them to the mounted directory in dosbox? I'd much rather use dosbox on my mac, if possible, instead of dos on windows 98 on virtual PC on the mac. Seems like the more direct, the better. Also less hassle transferring files too.
Thanks,
Dennis
Dennis W. Schultz
