First post, by ante1234and
hi
i have trouble getting blood v1.11 to work, that one with plasma pak.
i installed the patch pcd11 and when i'm about to start the game, it gives me an error that says this:
src\blood.cpp(2244): TILES###.ART files not found.
what am i doing wrong? i have setup the sound correctly and set the screen to 320.200 something. btw i run this on my retro pc with win98
Reply 1 of 4, by leileilol
Remove the read-only attribute off your files. This shouldn't happen with a proper installation
long live PCem
FUCK "AI"
Reply 2 of 4, by ante1234and
i removed all read only on every files
but when i start the game, i get another error:
src\db.cpp(1144): Error opening map file.
what can i do?
Reply 3 of 4, by vladimiro
Hello, are you using ems memory (Jemm)?
It happens to me in freedos with the jemm loaded.
use only xms memory.
Reply 4 of 4, by ante1234and
ok i try that and see if it works
