First post, by feipoa
I've been using Sysinternals FAT32 for NT4 for a long time now and has generally worked fine. I started running into issues when I began experimenting with CF cards as hard drives. FAT32 for NT4 comes with CHKFAT32, which is like chkdsk, but it checks the FAT32 volumes on your NT4 installation. The problem is that CHKFAT32 cannot seem to fix the errors it 'thinks' it found. Once it decides you have an error that wasn't cleared, CHKFAT32 will auto check your FAT32 HDD partition at boot time and will keep doing this until some flag is reset.
Does anybody know how to a) disable CHKFAT32, or b) reset the flag which tells CHKFAT32 to run at next boot?
I've had a cheezy solution to this which involved uninstalling and reinstalling FAT32 for NT4, but I'd like get this resolved. The real problem came when I used a Transcend Industrial CF170 compact flash card on a particular setup. Upon boot, CHKFAT32 thinks every cluster on this CF card is orphaned and at boot time, the messages of each cluster one by one roll down the screen. With a 64 GB card, you basically never get into the OS.
I see one other forum post about this issue, but there wasn't a solution listed. https://windowsbb.com/threads/161368/
Reply 1 of 8, by Warlord
some old version of systernals autoruns 8.73 or del reg key might do the trick
Reply 2 of 8, by bakemono
Does this information help? https://www.raymond.cc/blog/manually-reset-or … without-chkdsk/
I'm not sure if it applies to NT4. Also, they are resorting to a boot CD to edit their system partition because their hex editor isn't capable... I would suggest using Roadkil's sector editor to bypass that problem.
Another thought is that you could try replacing CHKFAT32.EXE with another Win32 console program that simply does nothing. (Or gives you the option to run CHKFAT32 or not)
Wreckage reimagined on itch: https://90soft90.itch.io/wreckage-dash
Reply 3 of 8, by feipoa
I deleted chkfat32.exe and NT4's blue screen still runs CHKFAT32 when booting. That's really curious.
I then compared all registry entries for "fat32" for the case of a) fresh install of sysinternals FAT32 for NT, b) configuration in which NT keeps checking my HDD at boot and finding "orphaned" clusters. There was no difference in these registry entries. Thus I must conclude that the flag setting to check my FAT32 partitions at boot is elsewhere. Unfortunately, I don't know where.
For this reason, I have uninstalled winternals FAT32 for NT4 and and now using FASTFAT32 to read my fat32 partitions from within NT4. I'll see if a similar issue emerges. So far so good.
Reply 4 of 8, by weedeewee
feipoa wrote on 2021-08-25, 10:37:
Did you check out the info on the link that bakemono commented ?
bakemono wrote on 2021-08-09, 15:22:
Do not ask Why !
Reply 5 of 8, by feipoa
weedeewee wrote on 2021-08-25, 11:22:
I read it briefly but decided it was not the most desirable type of solution and there is no certainty it would apply to winternals FAT32 for NT.
Assuming the winternals dirty flag is at the same location as the Windows dirty flag for FAT32, I would need to, according to that link, track down the dirty bit (for FAT32 only) at offset 41 (5 down, 2 across) to see if the value is 01, then change it to 00. As I didn't want to go through that step each time I have a hard reset or other application hang up, I decided it best to try fastfat32 first then revisit the HEX edit approach as a last resort.
Reply 6 of 8, by weedeewee
feipoa wrote on 2021-08-25, 23:24:
You might have looked a bit too briefly at it, since it has a section called
Clear the Dirty Bit for a FAT32 Volume […]
Finding and clearing the dirty bit for a FAT32 file system is far easier than NTFS because it’s located right at the start of the volume and is always at the same offset location. Here’s how to clear it.
Read More: https://www.raymond.cc/blog/manually-reset-or … thout-chkdsk/2/
fyi, it's on the second page to which I had sneakily linked.
and somehow the link sneaked into this quote?!
Do not ask Why !
Reply 7 of 8, by feipoa
Did you read my second paragraph? I read page 2 before I posted my reply above. This is how I knew offset 41 was the one to look for. However, I do not wish to clear this HEX value each time I have an error. I decided that it was easier to try fastfat32 first, then revisit HEX editing if both programs exhibit the same symptoms.
Reply 8 of 8, by weedeewee
feipoa wrote on 2021-08-25, 23:50:
Ha! no I didn't, I just glimpsed at it :-p
I'm off to bed. Goodnight 😀
Do not ask Why !
