First post, by cyberluke
Hi, I discovered strange issue. I already have 5 computers running XT-IDE. Now I'm trying to make it work on FIC PA-2005 (Via chipset) motherboard with Pentium 133 MMX. Just installed Windows 98 SE on CF-IDE (32GB).
Every time I restart (warm restart) the computer, XT-IDE will not show up and BIOS will fail to boot from HDD. On cold reset or computer turn off / turn on, it will work. It seems it is happening in Windows 98 SE.
The NIC is Realtek PCI with IRQ=10 and I removed all ISA cards. There is only S3 GPU in PCI. This Realtek NIC is supposed to be PnP, but there's no configuration utility. The only way to change stuff is in Windows 98 device manager. So I tried to change address of this Realtek PCI to C800 range as that is where is XT-IDE setup and that's what is reported on the boot.
But it did not help as well. Am I doing something wrong? I tried disabling as much IRQs as I can, but this does not seem to be IRQ conflict. I tried to change card positions as well. Nothing helps. I spent 2 days debugging this.
I have 5 Realtek PCI NIC. You cannot change IRQ, but each card have different IRQ by factory. I tried a few of them. It does not solve the problem.
I have also spare 3COM NIC for ISA, but when I run configuration utility I see BOOT ROM is enabled, but it reports address 0H. I cannot change this address. That is very strange and XT-IDE will not show up on this one. Another 3COM ISA can be changed. I guess it is different model or something is faulty on this one.
