First post, by Mu0n
I'm having a hard time running this game well on both a 486 DX2/66 (upgraded IBM PS/ValuePoint 425SX/S, running MS-DOS 6.22, 32 megs of RAM, no L2 present) and my custom Vortex86DX (same OS, speed equivalent to a P2 MMX 233 MHz, underclocking and L1 L2 disabling possible through BIOS). I've tried every trick I know:
-disabling L1, L2 cache
-underclocking the vortex86DX from 800 MHz to 25 MHz with a 32 cpu frequency divider
-running various CPU limiter apps, including moslo v1.32 (command.com is slowed down, then I can run the batch file this game wants, for its cfg command line parameter)
Here's a comparison video I made between dosbox and real hardware (p2mmx equivalent). All the above tricks do nothing to curtail the problems with the feed on the right of the video.
https://youtu.be/nnWHO_9iO8Q
The first obvious glitch appears around 1:15 and it gets worse and worse from then on.
Did people just give up entirely on running this game past the 386 generation?
1Bit Fever Dreams: https://www.youtube.com/channel/UC9YYXWX1SxBhh1YB-feIPPw
AnyBit Fever Dreams: https://www.youtube.com/channel/UCIUn0Dp6PM8DBTF-5g0nvcw
Reply 1 of 13, by leileilol
You aren't the only one.
Reply 3 of 13, by Gmlb256
Does the video glitches when there is no sound configured?
Feels like some kind of synchronization problem.
Reply 4 of 13, by Mu0n
Ok, now I'm super baffled. I copied the files to my 2nd Vortex86DX unit and......everything works flawlessly. I wish I could understand what's going on! The only difference is the media I'm using as a hard disk. They're slightly different SanDisk microsd cards....
edit - 2nd difference, I didn't install the game, merely copied the contents of an already installed game.
I'm back to a glitchy version after trying my luck with the patched .exe that adds MT-32 support to the CD version.
Reply 5 of 13, by Gmlb256
I'm curious about this. Does the BIOS settings and versions are exactly the same between the two Vortex86DX?
Reply 6 of 13, by Mu0n
Gmlb256 wrote on 2021-08-16, 19:08:
everything is exactly the same.
edit - no sound configured, I still have to figure out how to make it happen. The install utility doesn't give that option. I must blind-guess what to write in the resource.cfg.
Reply 7 of 13, by Gmlb256
Strange. As for why DOSBox doesn't have any issues in that game is due to the emulator hiding and addressing some of the issues that only occurs on real machines such as I/O delays.
Some BIOSes have an option to set the I/O wait states or something similar where increasing them could help with your situation.
Reply 9 of 13, by Mu0n
Soutbridge ISA Configuration
ISA Clock is at 8.3 MHz (at lowest setting already)
DMA operating clock at 4 MHz (lowest setting already)
ISA 16 bits I/O wait-state: switched 1 clock cycle to 4
ISA 8 bits I/O wait-state: switched 4 clock cycles to 6
ISA 16 bits Memory wait-state: switch 1 clock to 4
ISA 8 bits Memory wait-state: switched 4 clocks to 6
it still glitches
I then tried 8 clock cycles everywhere (except 16 bits mem to 7), with L1+L2 @ 800 and without L1+L2 @ 25 MHz, still glitches.
Reply 10 of 13, by Gmlb256
Have an interesting idea here that we haven't checked here before, can you try to run with EMM386 in CONFIG.SYS?
I recall that some games didn't work well without any expanded memory manager even if the game doesn't require EMS.
Reply 11 of 13, by Mu0n
Gmlb256 wrote on 2021-08-16, 22:37:
Wow. This is WILD. Despite expanded memory being my default configuration out of 9 in my autoexec.bat, I managed to always select conventional or extended memory in ALL my tests. I've tried running it with your suggestion twice, works. I tried rebooting, works.
Let's see the 486 now?
works.
thanks!
A fix so basic it could not have been it at the start!!!
Reply 12 of 13, by Gmlb256
You're welcome!
Reply 13 of 13, by leileilol
Ooh!
I can also confirm configuring EMM386 for EMS also fixes it on PCem (addressing last year's thread reply)
(though...there's older EMM386 versions which Willy won't play with due to DMA reasons. DOS 6.22's will be fine though)
