First post, by wbahnassi
I have this weird issue in my DOS build. Everytime the PC speaker is outputting sound, my keyboard seems to stop receiving input.
For example, playing Keen1, as you're having a long fall you cant control the character anymore until the fall sound stops.. same if there are many enemies shooting, you get effectively frozen because your keyboard inputs are ignored.
This is not on Keen1 only though, but any other game/program that is outputting to the speaker.
This happens on a modern Intel X58 mobo build (HP Z400). Keyboard is USB. On an old Pentium75 build there is no problem.
I'm wondering if anyone saw such symptoms or if there is anything I can try to fix this conflict.
Cheers!
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 1 of 2, by BitWrangler
Real keyboard gets DMA, USB doesn't, it's polled, as is the speaker. Basically both are cycle intensive, even if the CPU is fast.
Reply 2 of 2, by wbahnassi
Thanks! That was indeed the culprit. Using a PS2 keyboard instead of the USB one solved it.
Thanks a lot!
