First post, by Chadti99
- Oldbie
I’ve noticed with sound off that Turok is quite playable on either my POD100 or AMD5x86 180 machines paired with a Voodoo. As soon as I enable sound, things go downhill fast. Maybe this platform just can’t muster enough grunt to do it with audio, but it seems like it’s close. Adjusting the sound quality down to 11kHz seems to help but are there any other audio options worth changing? Is there a sound card that might offload some of the work from the CPU?
I do see a measurable performance difference in quake with the -wavonly option, compared to default direct sound. Maybe there is a similar option for Turok?
Does Turok have any way to measure fps?
Thanks for any help, ideas, suggestions!
