First post, by user33331
Hello
Rookie question. What is an easy USB-bootable software that formats laptop's main SSD (only 1x SSD) ?
- I tried to clone a drive unsuccessfully (m.2 NVME.) with a confusing Sabrent Acronis True Image and now Windows installation does not seem to format the SSD on its own because there are conflicting files already in it.
What USB-bootable software formats SSD for basic windows: 7,8,10,... installation ?
There were multiple screws and plastic clasps involved to dissassemble the laptop when replacing the m.2 NVME to bigger GB size and I would not want to do that again.
Is there such bootable formatting softwares available for USB ?
Reply 1 of 17, by kixs
Make Windows 10 bootable USB Flash drive. Boot from it. When it gets to the partitions - delete them all and press next. Windows will create the partitions it needs. - never had any problems with this way.
Reply 2 of 17, by user33331
I tried to remove partitions but it says "Chosen partition could not be deleted [Error: 0x800701b1]"
- USB media creation tool ISO.
The failed cloned partitions are there. They don't function well.
I need another way to format ssd without removing it again from laptop.
    60.11 KiB
Reply 3 of 17, by Bancho
Boot your Win10 USB media and select repair computer and select troubleshoot, then command prompt.
At command prompt type the following
diskpart
List Disk (lists current disks)
Select disk X (X being the disk you want to format, usually 0)
Clean
That should clean the disk.
You can also use diskpart to create the partitions.
Example for a single partition
create partition primary
format fs=ntfs quick
active
You should now be able to use the drive
Reply 4 of 17, by user33331
It says "error there is no defined device".
Virtual disk service error I tried disk 0 and disk 1.
    31.77 KiB
Reply 7 of 17, by BitWrangler
I would say you want to get back in there to make sure it's seated properly.
Reply 8 of 17, by user33331
Any idea if every brand of m.2 NVME is compatible with Thinkpad 570 ?
- Or are those approved coded in Lenovo BIOS ? You know "Whitelisted" SSDs is it possible ?
I tried 512gb Samsung 970 Evo Plus m.2 nvme.
It previously had OEM 256GB Toshiba THNSN5256GPUK m.2 nvme.
Reply 12 of 17, by user33331
Nope same error when installing win10 [Error: 0x800701b1].
Thinkpad T570 might have not whitelisted Samsung EVO 970 Plus 500GB.
M.2 NVME is visible in a normal PC using USB to m.2 NVME adapter=Sabrent EC-SNVE.
Drive is visible in BIOS of T570 but I can not install Windows to it.
    81.21 KiB
Reply 13 of 17, by user33331
I am now pretty much confident that Lenovo blacklist some SSDs in BIOS and whitelist others.
OEM 256GB Toshiba THNSN5256GPUK works right away but 500GB Samsung 970 EVO plus does not.
My other PC reads 970 Evo Plus well with USB to NVME adapter: Sabrent EC-SNVE.
I think twice next time I invest my money on Lenovo products.
Such an frustrating day.
Reply 14 of 17, by weedeewee
You could always try to mod the bios, or have someone mod it, to remove any whitelists present.
it's an odd error message.
I'd boot a linux live cd, and see if I can access the nvme drive. and if it's accessible (create filesystem, copy some files...), if accessible dd if=/dev/zero of=/dev/nvmesomethingorother count=2k to zero out the beginning of the drive. (would be nice to also zero out the ending of the drive but I can't recall the command from memory)
Do not ask Why !
Reply 15 of 17, by aha2940
user33331 wrote on 2021-08-19, 16:31:
I am now pretty much confident that Lenovo blacklist some SSDs in BIOS and whitelist others. OEM 256GB Toshiba THNSN5256GPUK wor […]
I have successfully replaced the hard drive on a Lenovo Thinkpad T14s, as well as a T470s, T440s and an X240. I've never had any problems. Actually, I'm typing this post on a Lenovo P14s on which I replaced the original drive for a Samsung SSD 980 NVMe, no issues at all, it does not seem to be any blacklisting on recent models.
Reply 16 of 17, by user33331
I think the German computer seller sold me a faulty used T570. Connection between SSD=m.2 nvme and motherboard seems disconnecting.
It starts sometimes normally to Windows but every 1/3 times it just goes to "Bios Boot=Windows Boot Manager/Boot Menu"-list and jams.
- It could be anyone of these 3x connectors that can be disconnecting connector pins.
What an nightmare.
It feels like when the machine is "cold"=OFF not used for a couple of hours it starts to Boot Menu and ignores SSD and when "warm"=laptop ON idling for couple of hours it is easier to boot to Win10.
- Maybe copper connectors expand due to heat and connection is better or it is just random hard to tell.
    51.35 KiB
    221.48 KiB
Reply 17 of 17, by aha2940
I would try to update teh BIOS to the latest version and see if there's any difference. Also, here are the user guide and hardware maintenance manual for your laptop, maybe there is something useful there:
T570 User Guide: https://download.lenovo.com/ibmdl/pub/pc/pccb … _p51s_ug_en.pdf
T570 HMM: https://download.lenovo.com/ibmdl/pub/pc/pccb … _sp40j65584.pdf
