First post, by Kahenraz
I'm testing a 440EX system which normally has a maximum memory limit of 256MB but will accept 512MB with two 2RX4 (dual rank) sticks. The issue I'm having is that Windows 98 becomes unstable with this combination but only when I'm running games.
I get different stability and anomalous results depending which card and which driver I use but all problems go away with anything less than a single 256MB stick in any combination of the two available slots.
I've tested several 2RX4 sticks and the problem is consistent no matter who made the chips on it, suggesting that the problem is not defective memory.
Running Memtest86+ does not produce any errors. As mentioned previously, I only have problems when I run games but these are the only tests I've run at all. Are there any memory stress tests for Windows 98 so that I can take the video card out of the loop? Something that can verify itself rather than just a benchmark which may ignore any errors would be ideal.
Reply 1 of 3, by Warlord
try loosening the timings. It might not run tight with that much ram.
Reply 2 of 3, by Kahenraz
I can only set the CAS Delay to 3 or 2. Neither setting makes a difference.
I also tried under clocking the bus from 66 to 50Mhz but this made no difference.
Reply 3 of 3, by AlexZ
If CAS 3 doesn't help then there is very little you can do except using a different set of RAM sticks.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
