First post, by Kahenraz
I've been trying to see how far I can upgrade this poor 440EX motherboard. It has a few overclock pins with up to 83Mhz FSP and a 5x multiplier. But I found that my Pentium 2 SL2WB (Costa Rica) was locked at 4.5x. I could at most achieve a 375Mhz overclock.
I had a few Celerons and some slocket adapters and decided to test if any of the Mendocino cores would work. My 533Mhz SL3PZ would not POST and there was no power-on beep. But my 400Mhz SL3A2 works! And because the multiplier is locked at 6x (higher than I could even select on the motherboard), I have a 500Mhz Celeron where I could only before have at most a 415Mhz Pentium 2.
I've already ordered a 333Mhz Pentium 2 which already supports a 5x multiplier to compare.
Reply 1 of 5, by AlexZ
I would expect Celeron at 500Mhz to be faster than 415Mhz Pentium 2, both at 83Mhz FSB. I used overclocked Celerons back in the day for gaming and they were much better than K6-2. The key was to increase FSB speed.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 2 of 5, by schlomoe99
Happy accidents like that are so gratifying in this hobby!
Reply 3 of 5, by Kahenraz
I ordered all of the CPUs I was missing around this era for fun and testing to see what the limits truly are. I hope there isn't any compatibility issue between steppings as I just purchased what was cheapest at each speed.
I have a couple of slockets but what's most interesting is that only the ASUS S370 worked with this CPU and motherboard. The other two, which are really meant for Pentium 3-era CPUs, do not. When I try to use these other slockets the system will not POST or beep and the CPU remains cool to the touch.
This is unfortunate because the ASUS slocket is taller than a normal slot 1 CPU and does not fit into the case I want to use.
The attachment IMG_20210823_204158.jpg is no longer available
The attachment IMG_20210823_204146.jpg is no longer available
The attachment IMG_20210823_204135.jpg is no longer available
Reply 4 of 5, by AlexZ
This is quite relevant for 440LX owners as well. Celerons are very cheap to buy as they are practically worthless except for testing unknown boards maybe. Get a couple of Celerons and keep the one that runs at 83Mhz FSB at 500Mhz.
When I tested my slotket with Celeron 366 on 440BX, it managed to POST at 550Mhz (5.5 x 100). Slotket was set to Auto & Celeron, but still somehow 100 Mhz FSB was set. It's a cheap "370spc rev 1.0" I got for €2 (same as discussed in Coppermine 1100 doesn't work via slotket ). Booting with Coppermine Celeron wasn't successful (regardless of Celeron or Coppermine being selected on jumpers) and I didn't dare to put PIII 733 into it as it didn't behave the way I expected with the old Celeron.
Reply 5 of 5, by stamasd
My latest build is a Socket A with an Abit KT7A motherboard. The maximum multiplier it supports is 13x, so with a FSB of 133 the max CPU speed would be 1729MHz. But an Athlon XP 2400+ with locked multiplier of 15x works fine even though it's recognized as "unknown CPU at 1997MHz" 😀
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
