First post, by LowMan
Dispite searching for and doing the solutions I've seen around here I still can't get Command & Conquer to work.
I've tried mounting my CDrom drive with "mount D D:\ -t cdrom -usecd 0 -aspi", I've tried making it a ISO, I've tried everything and all I get when I type "Setup" is:
Illegal Command: win
And it goes no further.
I know this works...I've seen several people around this forum saying it works. I just can't seem to get it installed! 😒
Help!
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
hmm isn't there an install command ?
as setup clearly wants to start windows (win)
Water flows down the stream
Reply 2 of 3, by LowMan
There is an install.exe but it does the same thing! 😒
Reply 3 of 3, by DosFreak
It's possible that you have the Windows only ver of C&C. I'll have to check my copy but I believe it's Win9x only. I think the last time I tried to get Dos C&C working with my 9x only copy I had to splice some Dos Covert Ops files together....
Make your games work offline
