First post, by Paar
Hi. I've been modifying my GA-586HX 1.55 motherboard (adding USB functionality) and made a short in the process. There is a resistor above the keyboard connector which has been damaged and to replace, I need to know it's value. Unfortunately it's no longer possible to read color designation of the resistor, nor measure it with multimeter. Could somebody with the same motherboard check it for me? I would be most grateful. Thanks!
    161.02 KiB
    GA-586HX 1.55 with damaged resistor
