First post, by Jackhead
Hi,
i tryed to change the resolution for GLQuake 0.98.
With the command line i want to change to 1600x1200x16 .
I tryed different resolutions. For example 800x600x16 work. When i go above the exe crash on startup with:
"Could not initalize GL (wgCreateContext failed)
Make sure you in are 65535 color mode"
Anything above 800x600x32 give me this error. What does it mean?
I tryed different windows color modes 16,32 but doesent help.
I use a voodoo 5500 with p4 3,06GHz and windows98SE .
Anyone can help?
regards
Chris
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - GUS ACE - MPU-401AT with YucatanFX
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 1 of 3, by Gmlb256
Is there a OPENGL32.DLL file on the directory where GLQuake is located?
If so, remove it as that one was a MiniGL implementation for older 3Dfx cards.
Reply 2 of 3, by Jackhead
Gmlb256 wrote on 2021-09-01, 20:23:
That was the Problem. Many thanks!!
Reply 3 of 3, by Gmlb256
You're welcome!
