First post, by Kahenraz
Please be aware that this is the only system I have built at the moment for testing DOS and Windows 98. It is not an ideal match for this generation of cards by any stretch and this information is instead presented simply as a test case for driver compatibility. I found this pairing to be especially interesting because it is so underpowered that there is measurably no performance difference between a GeForce 5200 and a 5950. There are some minor exceptions when comparing a benchmark that heavily uses shaders where the heavy lifting is being done by the GPU but overall performance in these situations would not be considered playable anyways.
Very basic software tests were performed to test for stability and graphical glitches. Not all tests were run to completion and specific performance characteristics were measured subjectively. These tests were done with the intent of testing a wide range of cards quickly to narrow down which drivers would be useful for proper testing and comparison later if the need arises.
Software tested:
Unreal (Direct3D)
Unreal Tournament (OpenGL)
3DMark 99
3DMark 2000
3DMark 2001
NVIDIA T&L Water Demo (here)
Both Unreal and UT were installed from the Unreal Anthology and no additional patches were used. Both 3DMark 99, 2000, and 2001 use the latest versions provided directly by FutureMark; this is important to note as there are different versions and updates were made to the original release. The NVIDIA T&L Water Demo is important because it is a very easy way to identify when compatibility starts to break in later driver versions.
Driver versions tested, 45.23, 53.04, 56.64, 61.76, 66.94, 71.84, 77.72, 81.85, 81.98.
OS is Windows 98 Second Edition stock with no additional service packs or updates. I don't think there are any updates that would have made a difference for these tests.
System specs are an Intel 440EX paired with a Pentium 2 at 300Mhz and either 128MB, 256MB ,or 512MB of RAM (more on why this is important later).
Test summary:
45.23
Works great but only supports a limited set of FX cards. Unreal displays only yellow to the screen when 256MB memory sticks are installed (Tested with FX 5200 AGP, Quadro 500 AGP; does not occur with FX 5950 AGP).
53.04
Works great with all software tested.
56.64
61.76
System will immediately bluescreen when loading a Direct3D game or benchmark. OpenGL works fine.
66.94
Graphical corruption and screen flickering in Direct3D games and benchmarks. Causes general system instability when software that failed to render correctly is closed.
* NVIDIA T&L Water Demo is missing light model.
71.84
Minor graphical corruption in 3DMark 99 benchmark. Alpha blending corruption in 3DMark 2000 slash screen when starting up. Starting 3DMark 2000 benchmark causes it to crash immediately; 3D acceleration becomes disabled and requires a system reboot for it to be restored.
77.72
3DMark 99 benchmark graphical corruption is gone. Alpha blending corruption in 3DMark 2000 splash screen is still present but the benchmark no longer crashes.
* NVIDIA TLWater demo is missing light model.
81.85
Alpha blending corruption in 3DMark 2000 splash screen is still present. 3DMark 2000 and 2001 benchmark has graphical flickering. Driver cannot be uninstalled from Add-Remove Programs; Nvudisp crashes with an invalid page fault. The driver must be uninstalled with DH Driver Cleaner instead.
81.98
Alpha blending corruption in 3DMark 2000 splash screen is still present. 3DMark 2000 and 2001 benchmark no longer flickers. Driver cannot be uninstalled from Add-Remove Programs; Nvudisp crashes with an invalid page fault. The driver must be uninstalled with DH Driver Cleaner instead.
Detailed summary of tests is as follows.
Detonator FX 40-series drivers :
Version 45.23 which is widely considered to be the "most compatible" by many users here on the forum had a very specific edge case in my testing. When running Unreal with the Direct3D renderer with a GeForce FX 5200 or Quadro 500 the game would launch but only a yellow screen would appear as the startup demo and music would play. Pressing Escape to exit the startup demo does not change anything and the screen is still solid yellow. The game is NOT frozen and I can exit the game by clicking the mouse in the top left corner and using the keyboard to navigate the menu to exit.
This issue is limited to Unreal only when using the Direct3D renderer, does not occur in Unreal Tournament (a very similar engine) or any other benchmark or test, and specifically occurs only when the system is equipped with either one or two 256MB memory sticks. Changing timings, AGP aperture, and swapping to a different brand of memory did not change this behavior; only lowering the amount of system memory would make the yellow screen go away.
Note that I had a limited set of cards at the time that would work with 45.23. The FX 5200 and Quadro 500 are similar enough that seeing the same bug occur for both cards is not unexpected. But what was unexpected was that this issue is not limited to just the driver version but also the card being used. The only other card I could test with this driver version was a 5950 which does NOT produce a yellow screen. Further testing is needed but it's interesting to note this edge case which involved an 45.23, an FX 5200-class GPU, and a very specific size of memory stick. The yellow screen did not occur when tested with any other card including a GeForce 4 MX 440, GeForce 3 Ti, and a Quadro 4.
ForceWare 50-series drivers :
This next version 53.04 fixed the "yellow screen" bug in Unreal. Everything else tested great and no problems with all of the 50-series of drivers.
ForceWare 60-series drivers :
This is the beginning of the end when it comes to FX compatibility in 9x, at least in my experience. Certainly some titles will play better with added performance but my experience was pretty terrible. Version 61.76 would not work at all with any Direct3D title on ANY card FX or prior and would immediately result in a BSOD. Interestingly, OpenGL works fine.
The next release version 66.94 was a bit better but produced graphical glitches and crashing to desktop would inevitably lead to system instability. I would not trust this driver for regular use outside of testing. This is also the first driver to produce a very strange bug in the T&L Water Demo where the light bulb model is completely missing. This bug exists up until the final driver release version 81.98.
ForceWare 70-series drivers :
This is when graphical corruption began to creep into 2D effects as well. For example, corruption in alpha blending effects which are probably bugs introduced by 2D GDI acceleration. This is very bad as it means that oddities will start cropping up even outside of 3D accelerated games.
ForceWare 80-series drivers :
2D corruption is still present in certain situations up until the very last version 81.98 driver. This is also the first version to introduce a new bug which caused Nvudisp to crash with an invalid page fault when attempting to uninstall via Add-Remove Programs. The only way to uninstall 80-series drivers is with DH Driver Cleaner.
The first release, version 81.85, produced a strobing effect in 3DMark 2000 and 2001. This was solved in the final driver version 81.98.
Bugs still present in the final Windows 9x release version 81.98 include 2D corruption (possibly related to GDI), the inability to uninstall the driver from Add-Remove Programs, and the missing light model in the T&L Water Demo.
In my experience I have found version 56.64 to work without issue and is the very last version before strange oddities and other glitches started to creep in.
It is expected that some of the bugs and problems I experienced are be due to the code path that the drivers used on my particular system. For example, certain bugs may not occur if your CPU has SSE or 3DNow! which may use a different code path. I suspect that this is the case as I have read of other people here on the forum using driver versions which do not work at all for me. Unfortunately, this particular system refuses to work with a Pentium 3 to enable SSE. Further tested would be required to see how this affects driver bugs and stability.
214.64 KiB
596.25 KiB
487.24 KiB
468.04 KiB
Reply 1 of 17, by Kahenraz
3DMark GDI alpha blending corruption:
113.8 KiB
Nvudisp general page fault when attempting to uninstall:
6.62 KiB
NVIDIA T&L Water Demo bug with light present and missing:
88.59 KiB
88.51 KiB
Reply 2 of 17, by Kahenraz
Related video by Phil on drivers. This isn't directly comparable with my testing as our test setup and objectives were different but still a good source of information:
https://www.youtube.com/watch?v=HRhm4aGNI3o
Reply 3 of 17, by Kahenraz
I've finally managed to track down the cause of the driver instability I've been experiencing since version 56.64 in my testing. It comes down to Nvidia having a different code path for SSE-enabled processors or a bug introduced by a new optimization. This can be demonstrated exactly by the T&L demo with the missing light.
When testing any Pentium 2 or "Mendocino" Celeron, the light model disappears, graphical glitches begin to occur, and drivers overall become unstable. But without changing any drivers I swapped my CPU for a Coppermine and suddenly everything renders properly and the drivers become stable.
On a similar note, the Dawn demo will crash when run without a processor that supports SSE but only on NT 2000 or higher. It will still crash on Windows 98/ME even with SSE, but this may be for a different reason.
Reply 4 of 17, by deksar
Very useful post with great details! It helped me a lot, just wanted to thank you Kahenraz.
Got an GeForce 4 MX 440 - 64 MB AGP card. I was having lots of troubles with 81.98 forceware, I couldn't even uninstall it (seems a known bug), the uninstall process is corrupted, but version 56.64 seems solved everything! No more dll crash, on Win98SE.
Thanks.
Reply 5 of 17, by Tetrium
This is indeed very nice 🙂
My retro rigs (old topic)
Report spammers here!
Reply 6 of 17, by RandomStranger
It's good that you do it, and I understand you want to keep this to only a handful of software being tested, but 3 synthetic tests and 2 games using the same engine feels a bit too limited.
The testing environment: Win98BOX
My experiences regarding this with an FX5700 using the following games:
Aliens vs. Predator 2
Colin McRae Rally 2.0
Half-Life (using OpenGL renderer)
International Rally Championship
Need for Speed: High Stakes
Need for Speed: Hot Pursuit 2
Prince of Persia 3D
Quake III Arena
Serious Sam
Unreal (using DirectX renderer; patch 226final)
All the games were original retail releases.
As well as 3DMark2000 and 2001SE
45.23
Unsupported
53.04
Everything works fine, except NFS:HS which doesn't launch/crashes to the desktop right away.
56.64
Everything works fine, except NFS:HS which can only go up to 640×480 using 32bit color depht in 3D accelerated mode while awfully slow in 16bit.
61.76
Everything works fine, except NFS:HS which has a buggy main menu in 3D accelerated mode, with complete black screen and flickering panels when items are open.
7.97 KiB
Reproduces the bugs you experienced.
71.84
3DMark 2000 crashes to the desktop when starting default benchmark. No additional issues, like alpha blending corruption on the splash screen or disabled 3D acceleration.
3DMark 2001SE works fine.
AvP2 crashes upon launch with an error messege: "AVP2 Error: Couldn't set D3D Emulation mode."
CMR2 crashes upon launch with an error message: "This program has performed an illegal operation and will be shut down."
Half-Life works fine.
IRC freezes the whole system with black screen. Reset needed.
NFS:HS crashes with an error message ("AMF=16 platformc(347)") in 3D accelerated mode, simply crashes to de desktop in software mode.
NFS:HP2 works fine.
PoP3D freezes on loading a game save. Only the game, not the whole system.
Q3A works fine.
Serious Sam works fime.
Unreal works fine.
Stability issues with Explorer/Active Desktop. Issues with uninstalling the driver from the Control Panel. Driver Cleaner necessary.
P.S.: I use DC anyway to remove leftovers after testing.
77.72
3DMark 2000 works fine.
AvP2 buggy loading screen, texture bugs during gameplay, single digit frame rate.
CMR2 buggy menu, texturing errors and other corrupitons during gameplay.
IRC works fine.
NFS:HS same buggy menus as with 61.76 cannot be navigated.
NFS:HP2 works fine.
PoP3D the save game loads very slowly, otherwise works fine.
Q3A works fine.
Serious Sam works fine, but about 20-25% slower than with older drivers. Still firmly 60+ fps.
Unreal works fine.
728.57 KiB
199.66 KiB
AvP2 the previous errors persist.
CMR2 the previous errors persist.
IRC works fine.
NFS:HS loads the main menu without graphical issues, then the game immediately freezes.
NFS:HP2 works fine.
PoP3D slow loading fixed, works fine.
Q3A works fine.
Serious Sam works fine, but the performance issue persists.
Unreal works fine.
None of the drivers were without issues, I decided to stay with 56.64 which seems to be the most compatible and over all the fastest by a very small margin.
Edit:
Need for Speed: High Stakes is a general incompatibility/bug. Fix is here: Re: What retro activity did you get up to today?
With this it works in 1280×960@32 with a fixed 65fps (monitor refresh rate set to 75Hz, it's 60fps with 60Hz) using driver version 56.64. I'm lazy to check the game again with the rest of the drivers.
Reply 7 of 17, by Kahenraz
I haven't done extensive testing for game compatibility, but I wanted to share that 81.98 is very stable on my Intel i945 with Pentium D 945. This adds further evidence that driver compatibility appears to be very dependent on the CPU feature set.
I was also able to get a Quadro FX 1300 PCIe working with drivers from the 60 series and above with Windows 98, but with a lot of problems. For example, Unreal lags horribly on the FX 1300 but is smooth on an FX 5200. The FX 5200 could also run Doom 3 just fine, albeit very slowly, while I could not get the FX 1300 to run it on any driver version without graphical glitches, corruption, or crashes. I was able to get Morrowind to run on both cards, but performance was about the same, with around 15 FPS at the starting town of Seyda Neen. For comparison, the FX 1300 on the same machine is able to maintain about 60 FPS in the same area on Windows XP.
Radeons are definitely more stable on Windows 98 with PCI Express. It's arguably useless on a GeForce FX.
Reply 8 of 17, by Kahenraz
Following up on this. I found that Thief 1 was locking up at a black screen when starting a game with my GeForce 2 MX on a 440BX and a Pentium 3 Coppermine on Windows ME. I tracked the problem down to the NVIDIA display driver I was using, 56.64. I downgraded to 45.23, and the game worked fine.
I can also confirm that this problem also exists with Thief 2. Both games are fully patched.
Reply 9 of 17, by AlexZ
45.23 is the driver to go for Windows 98 for FX graphics cards. This excludes GeForce FX 5700. Driver compatibility has been discussed many times here, it's a closed issue. Anyone testing 5x.xx drivers is just wasting their time. They may appear to work fine at first only to encounter issues with games like Thief or Need for Speed Porsche 2000.
It would be interesting to find out if Athlon (without SSE) would also have the same issues as PII. Athlon 1-1.2Ghz is another great choice for Windows 98 rig.
Pentium III 900E, ECS P6BXT-A+, 384MB RAM, NVIDIA GeForce FX 5600 128MB, Voodoo 2 12MB, 80GB HDD, Yamaha SM718 ISA, 19" AOC 9GlrA
Athlon 64 3400+, MSI K8T Neo V, 1GB RAM, NVIDIA GeForce 7600GT 512MB, 250GB HDD, Sound Blaster Audigy 2 ZS
Reply 10 of 17, by deksar
AlexZ wrote on 2022-10-20, 18:02:
Completely agree on FX cards. But Alex, how about GeForce 4 MX 440 (64 MB AGP)? What would you recommend for MX ones, as the most stable one?
Reply 13 of 17, by zyga64
In Windows 98 I'm using 40.72 drivers for Geforce4 MX440. Super stable, and never found any incompatibilities.
1) VLSI SCAMP /286@20 /4M /CL-GD5422 /CMI8330
2) i420EX /486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
3) i430FX /K6-2@400 /64M /Rage Pro PCI /ES1370+YMF718
4) i440BX /P!!!750 /256M /MX440 /SBLive!
5) iB75 /3470s /4G /HD7750 /HDA
Reply 14 of 17, by AlexZ
GeForce 4 MX440 64MB AGP (non SE version) is an excellent card for Windows 98 retro rigs. It still has excellent price/performance ratio.
AGP GPU benchmarks from ixbt.com - 101 cards tested revealed these older graphics cards can have an edge over GeForce FX series in some old games, although will trail them in others. With some GeForce 4 MX 440 versions one can also use older drivers than 45.23, e.g 28.32.
