Darksun and Darksun 2
First post, by FreeKnight
Hey Guys,
I'm trying to play darksun shattered lands from the cd masterpiece collection edition (patched) and when I try to run it a bunch of giant sized incoherent characters appear at the top of the screen then it returns me to dosbox prompt without the game having loaded.
When I try to play wake of the ravager it says the cd isn't in the drive, but it is, how do I enable a cd rom from dosbox (but without making my default prompt run from the cd?
I did search for some answers and read the guides but didn't have much luck, what can I say I'm a noob
Adam
Reply 1 of 9, by avatar_58
Mount C: C:\
Mount D: D:\ -t cdrom (replace with the letter of your cdrom drive)
C:\
Cd\darksun
darksun
Reply 2 of 9, by FreeKnight
Thanks that solved my cd problem, now I get Mel Fatal error #26 trap #16 any tips?
Reply 3 of 9, by avatar_58
Did you run the sound setup? If so, what did you choose? Make sure it works in this menu before trying the game.
Also, how many cycles are you using? Try lowering them. Also both normal and dynamic Cores in the config.
I have darksun 1 and I know it works. I've avoided the second one due to reports of many bugs...
Reply 4 of 9, by FreeKnight
I started changing the sound configs and I got shattered lands working (so far)
I've got ravager sound setup as a Soundblaster 16 and my cycles are 5000, it runs now, and plays the opening music but I'm getting no video/graphics
Thanks for your help so far by the way I appreaciate it.
Reply 5 of 9, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Use -ioctl switch when mounting CD.
Mirek
Reply 6 of 9, by mirekluza
DOSBox Moderator
Mirek
Reply 7 of 9, by FreeKnight
so my cdrom mount command line should looke like
mount d d:\ -icotl cdrom right?
Reply 9 of 9, by FreeKnight
Hey,
I tried it and I still get the opening music but still no sound, Is there maybe an incompatability issue between the vid type and the default dosbox settings?
