First post, by Almoststew1990
I have an Audigy 2 ZS and I don't think it has a front panel header on it for the headphone and mic ports on my case.
If I plug the header into the motherboard's audio will it direct my soundcard'a audio back to the motherboard and to the front panel? Or would I I have to enable the motherboard's built on audio for that to happen (and it wouldn't use the Audigy at all when using the front panel headphones).
It's a 1156 motherboard so I think it's "HD audio" connector rather than AC97 if that makes a difference.
Reply 1 of 4, by TehGuy
The front panel audio connectors generally go into whatever device you want to handle the audio. Motherboard if you want it to do it, soundcard if you want it to do it
Either way, only front panel anything for the 2 ZS I'm aware of is the breakout box, SB0250; I don't think it has AC97 or HD audio connectors.
Win98+DOS: C3 Ezra-T 1.0AGHz / P3-S 1.26GHz, 128MB RAM, AWE64 + Orpheus + Audigy 2 ZS, Ti 4200, 128GB SD card
Win XP SP3: C2Q 9650, 4GB RAM, X-Fi Titanium, GTX 750
PowerMac G4 QS 800MHz + GeForce4 Ti4200, OS 9
PowerMac G5 DP 1.8Ghz + ATi x800 XT, Leopard
Reply 3 of 4, by mastergamma12
dr_st wrote on 2021-09-03, 17:56:
Indeed it does not, but it's possible to make an adapter cable like described here:
http://audigy2zshowto.blogspot.com/2005/05/wa … stroy-your.html
I think some eBay/AliExpress shops may sell such cables.
Yep, I use that adapter on my X-Fi Xtreme Music to get front panel out on my X58 Lanparty rig.
