First post, by tinmachine2
--- From the Saga ... Old DOS Black label----
Hi folks how was it .... I hope you are all well !!!
If anyone is interested in this video card Paradise PVGA ISA 16bit Memory
... I would be interested in swapping it with a pci video card model Trident, T-seng
Unfortunately I have lost the ISA adapter from stripline to normal ISA connection
The vga needs the bracket video connector which unfortunately lost it, but it was extracted from the working pc
PARADISE PVGA 1024 PVGA1AISA 16 BIT ISA VIDEO CARD 62-00 3095 WDC '88 VGA16
Very Rare hard to find ISA Video card from decades ago
Great Bargain on this Vintage tested Paradise 16 Bit card!
From the Manufacturer:Western Digital
Codename: PVGA1A Bus:ISA 16bit Memory
Size:256kB Max Memory Size:
1MB Memory Type: DRAM
Year:1988 Card Type:VGA Process tech:1.25 µm
Made in :Singapore Owned by:Vlask, Palcal
Outputs:15 pin D‐sub Power consumption (W):
1 Core Clock (MHz):36 Memory Clock (MHz):42 Memory Bus Width:16bit Sold by:HP Paradise
