First post, by Kahenraz
Someone I purchased from recently sent me a photo of a bunch of processors that appear to be mostly 486 and early Pentium-class CPUs and asked if I was interested in any of them. I don't collect desktop parts earlier than ATX which leaves out the 486 processors. And none of the Pentium-class CPUs looked particularly interesting.
The only thing that stood out was the Pentium Overdrive but I don't think the ones here are anything special; it's hard to tell but I think they are meant for a 486 socket as well. There are some Cyrix processors but I can't see any reason to use one and I don't plan on ever collecting them.
Can anyone spot anything here that is worth buying?
394.25 KiB
Reply 1 of 18, by Caluser2000
Depends on what you are interested in. I'd personally grab all the overdrives, 200mmx +s, AMDs, and Cyrix cpus.
Reply 2 of 18, by Gmlb256
Same as Caluser2000 said, Socket 7 is my favorite platform.
Also there is a P4 CPU for Socket 423 and two AMD K7-based CPUs in that collection.
Reply 3 of 18, by BitWrangler
At a buck each I'd take all of them, at $5 each I'd take the MII-366 and the two overdrives, but I ain't really motivated to buy otherwise, even though they all go for $15 and up on eBay these days. However if you're looking for things that could potentially go in ATX boards in future, row 1: 4 and 5 ... row 2 and 3: 2,3,4,5. though I guess the pentiums will work in those s7 ATX boards too, but *yawn*.
Reply 4 of 18, by rmay635703
Although of zero interest to you the DX50 is uncommon
That non bespoke 286 could be interesting depending on its speed grade (4mhz and 25mhz are the most interesting)
High clocking of Cyrix are uncommon
200mhz + Pentiums of any flavor are practical
The newer stuff is up to you, P4 is pretty worthless for me but if you have proper boards, etc why not.
Really depends what you are hoping to get out of this.
And chips don’t exactly take up loads of space so it comes down to cost, if they are almost free or very cheap your not out much.
If they are more expensive you got to figure out if you will use it and what the market value is.
Reply 5 of 18, by drosse1meyer
I like the colored anodized heatsinks 😀
What is that tiny chip in the bottom row?
Reply 6 of 18, by BitWrangler
Might be a dustcap for a 387 socket.
Reply 8 of 18, by retardware
rmay635703 wrote on 2021-09-04, 19:52:
And useful!
If you have such one, keep it for mobo testing.
Reply 9 of 18, by Kahenraz
I made an offer for these and they arrived a few days later. I only had a single K6 for my Socket 7 and decided that a few more plus some extras seemed reasonable.
The title of the listing makes me feel like an archeologist. "Ancient Bundle"?
284.35 KiB
499.57 KiB
Reply 10 of 18, by drosse1meyer
pretty good deal for $20
Reply 11 of 18, by Kahenraz
The tiny chip from the bottom row is a socketed 8 Mhz 286.
296 KiB
257.81 KiB
Reply 13 of 18, by Kahenraz
There is an Intel 486 DX2-66 Overdrive and a Socket 7 Pentiun Overdrive. The Pentium Overdrive is marked as a Pentium MMX SL24W.
What makes some Pentium Overdrives command a high list price on eBay? What makes an Overdrive desirable when there are plenty of other cheap Pentiums available for Socket 7? The integrated fan would be less desirable I think because it's not replaceable.
I think the Pentium Overdrive would be more interesting if it could be dropped into a 486. But for Socket 7 it doesn't seem very useful.
370.04 KiB
299.3 KiB
258.47 KiB
249.31 KiB
358.07 KiB
Reply 14 of 18, by BitWrangler
Possibly you can stick that Pentium overdrive in a socket 5 board that otherwise maxes out at 120, but you'd have to check it out. The DX2 overdrive, well, I never saw a point in those, every DX33 board I've met will take a 5V DX2, must be some reason for it's existence, easier for OEM systems? I dunno.
edit: oh yah, regulator should be on board that pentium OD, so it will upgrade single plane socket 7 boards to mmx that only take p54, like most 430FX and some early HX, VX and TX though all those are more likely overall to support MMX native.
edit2: Doh, today I am just remembering that boards with soldered down CPU exist with an upgrade socket that will only take an overdrive with it's extra "check max spend occurred" pin.
Reply 15 of 18, by Gmlb256
The Pentium MMX OverDrive CPU is only useful on early Pentium motherboards are unable to supply the necessary voltages for a non-OverDrive Pentium MMX. There are also Pentium OverDrive CPUs for 486 motherboards that can support this adequately.
Reply 16 of 18, by Tetrium
Gmlb256 wrote on 2021-09-09, 02:53:
Could perhaps be interesting in some experiments using the disabled fan to underclock it?
Though I am unsure how the s5 PODs are affected.
My retro rigs (old topic)
Report spammers here!
Reply 17 of 18, by Gmlb256
Tetrium wrote on 2021-09-09, 21:16:
Sadly I don't have any OverDrive CPUs to do this experiment. 🙁
If the CPU has the multiplier unlocked downwards then it's possible to underclock it, even more with the FSB set to 50 MHz. The only Pentium CPU where I did underclocking was a normal P233MMX (1.5x multiplier not available due to being actually 3.5x) by changing the multipliers and FSB on a Socket 7 motherboard.
Reply 18 of 18, by DJMadMax
Uh, great find, great deal! Enjoy your stuff, there's definitely nothing "crappy" in it. Each of those processors tells its own story and has its own charme. Depending on it's task area there is not one useless processor in this lot. Kudos! 😀
