First post, by Rikintosh
PCEm suffers on my core2quad for a simple 486 dx2. I plan to set up a virtual hd with everything I ever use, so that when I have to format my real computers, I would just clone the hd image.
VirtualPC 2007 was good, but it doesn't seem to work anymore on windows 10
Take a look at my blog: http://rikintosh.blogspot.com
My Youtube channel: https://www.youtube.com/channel/UCfRUbxkBmEihBEkIK32Hilg
Reply 1 of 12, by canthearu
DOSBOX (and it's derivatives) are the gold standard DOS emulators.
If you were happy with what VirtualPC was offering, DOSBOX should be just as good.
Reply 2 of 12, by Rikintosh
canthearu wrote on 2021-09-06, 05:25:
I like dosbox but I find it annoying having to restart the emulation every time I need to change cd (iso)
Reply 3 of 12, by jesolo
I seem to recall being able to run up to a Pentium 100 MHz within PCem quite satisfactorily on my Core2Quad Q6600 (overclocked to 3 GHz) with Windows 7 32-bit.
I presume you are using the latest version of PCem?
You can perhaps also try one of the forks - PCem-X.
However, the hardware on which your running is a bit outdated (especially if you're running Windows 10 on it). If you have a later generationCore i5, then you should see much better performance.
Reply 4 of 12, by Gmlb256
Rikintosh wrote on 2021-09-06, 04:32:
PCem is more close for emulating an actual PC but requires a very fast CPU.
VirtualPC was replaced by Hyper-V and using virtual machines isn't the ideal experience for emulating an old computer.
DOSBox isn't even accurate when it comes to emulating a computer, it's more useful if you just want to play DOS games without any hassle. Also it's not ideal for running a Windows 9x operating system.
DOSBox-X is the most accurate among the derivatives but requires dealing with the configuration file a bit more due to the complexity and can be slower than DOSBox.
Reply 5 of 12, by jmarsh
Rikintosh wrote on 2021-09-06, 16:35:
You're doing something wrong, there's no need to restart the emulator to change the mounted ISO or any other drive.
Reply 6 of 12, by Rikintosh
jmarsh wrote on 2021-09-06, 19:26:
Sorry, I phrased it wrong and didn't tell the whole story. I usually use windows 3.1 so i have to exit it to switch isos
Reply 7 of 12, by Gmlb256
Rikintosh wrote on 2021-09-06, 19:56:
A negative side effect when using early Windows versions with DOSBox.
Reply 8 of 12, by Caluser2000
Shouldn't you be able to run multiple versions of DosBox without any need to unmount/mount anything?
Reply 9 of 12, by Jo22
Gmlb256 wrote on 2021-09-06, 20:16:
I haven't tried recently, but shouldn't ""
IMGMOUNT -U -D" and "RESCAN" command work from within Windows, too?
WinFile, ProgMan and DOS prompt should be able to execute these.
Reply 10 of 12, by Gmlb256
Jo22 wrote on 2021-09-06, 22:18:
I haven't tried recently, but shouldn't "" IMGMOUNT -U -D" and "RESCAN" command work from within Windows, too? WinFile, ProgMan […]
Admittedly, I haven't tried using DOSBox commands from Windows either. 🤣
However they are COM files located at Z: in DOSBox and probably may affect the amount of drive letter used on Windows unless they're identified as "removable". In the case of Windows 9x a generic ATAPI CD driver could be used if the image was mounted prior.
Reply 11 of 12, by jmarsh
You can mount all the ISOs (different discs) with one imgmount command and then use ctrl-F4 to switch between them, no need to exit windows or use the command prompt to issue a new imgmount command.
Reply 12 of 12, by Jo22
jmarsh wrote on 2021-09-06, 23:57:
Or just go the old school way and mount a virtual CD-ROM driver, like MagicISO! 😉
It may sound stupid at first, but it works and is sometimes more convenient
than using the internal method.
I've been using this unconventional method approx. since the mid-late 2000s.
Back then, I had many CDs backuped up in NRG format, incl. mixed-session ones with audio-tracks and mac file system tracks.
Using the virtual driver was simpler and cleaner than converting to bin/cue/ogg.
