First post, by lowlytech
I have a video card that will loose sync, but does boot up half the time, but before POST finishes, the screen starts flickering and goes out. The system will sometimes resync and the display is there where it left off. I think that the inductor L5 may be bad. This goes to pin 14 on the VGA port. When I measure resistance on L5 i get somewhere around 1K ohm. All the other L components in this area test at .20 Ohm, so quite a difference.
Question, can I just take off any surface mount inductor off another card I have that tests at .20 Ohm? Not really sure on how to match up what part I need to try on these very small SMT parts.
Thanks again for any suggestions.
