First post, by Yopachi
I've got an onboard sound chip labeled "ESS ES1968s" It plays well with windows 98se when I install VxD drivers for the "Maestro-2" The problem is that games with CD music aren't supported with VxD in DaemonTools. While googling I encountered a Korean blog with a table listing the drivers for ESS sound cards. The column for windows 98se seems to imply (WDM) support but I can't find a download that turns up with WDM drivers.
What sound card do yall recommend for windows 9x era cd games?
    78.55 KiB
Reply 1 of 13, by cyclone3d
Not seeing anything from the archived ESS site though they do link to Microsoft for more info.
http://web.archive.org/web/20000229140316/htt … vers/driver.htm
http://web.archive.org/web/20001208204200/htt … vers/driver.htm
And all driver files that were archived before they moved to ftp.
https://web.archive.org/web/*/http://www.esst … dable/drivers/*
Edit:
So, those WDM drivers with the weird VXD name on the newer driver site I was able to find. That driver contains the VXD and WDM drivers from the looks of it.
ESS newer driver site:
http://web.archive.org/web/20030604141739/htt … pp/drivers.shtm
That gives us the file names of the drivers via the links.
Did a search for the file name and found a working download on Softpedia.
I have uploaded it to my Google Drive for now:
https://drive.google.com/drive/folders/11_Fb_ … 1MH?usp=sharing
I'll do a proper archive of all the ESS drivers when I get a chance.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 13, by cyclone3d
It looks to me like you should be able to switch between the vxd and wdm drivers but I could be wrong.
You can try going into device manager and tell it to update the driver and then see if it will let you manually select the vxd or wdm.
YMF7x4 Guide
Reply 4 of 13, by ragefury32
cyclone3d wrote on 2021-09-15, 05:31:
For the ESS Maestro 2/2e/3/Allegro-1 you can swap between VxD and WDM drivers in Win98 (did that on the Dell C600 and the Compaq n600c). The VxD drivers are better for DOS compatibility, while the WDM is slightly more stable/efficient. Dell archives for the Latitude C600/Inspiron 4000 should contain support for both. For the old Win98 CD based games (read: DirectX, not DOS) and it needs to sit on the PCI slot, the ESS Maestro/Allegros are fine - some also swears by the Crystal CS4630 (Turtle Beach Montego and the like) , or something based on the Yamaha OPL3/YMF7x4. There’s also the Aureal Vortex2, which is fine but a bit more expensive.
Of course, if you want DOS compatibility that's something different.
Reply 5 of 13, by Yopachi
Tried updating from device manager and it doesn't give an option for wdm. Is there another way?
Reply 6 of 13, by cyclone3d
I'll have to see if I have a Maestro 2 card and then see what I can come up with.
YMF7x4 Guide
Reply 7 of 13, by cyclone3d
Well, I looked through all my PCI sound cards and didn't find any with a Maestro 2 chip.
Pretty sure I don't have a laptop with one either.
After looking at that driver installer again, it looks like it really is only a VXD driver set. I also did some more searching and was not able to find a WDM driver set anywhere.
YMF7x4 Guide
Reply 9 of 13, by cyclone3d
Well, I supposedly have a Maestro 2 based sound card on the way. It was one I had been watching for a few months. The box says it is Maestro 2 but who knows it it is actually a 2 or 2E.
I'm wondering if it will have WDM drivers on the install CD or if maybe I can get the 2E WDM drivers working on a regular 2.
YMF7x4 Guide
Reply 10 of 13, by cyclone3d
I found this on Drivergiude - they had been down for a couple days and this was the first time I was able to look there.
ess98.zip
129.33 KiB
89 downloads
It is a WDM driver but not sure if it is for Win9x or XP as the .INF doesn't say. It is for the Solo-1, Maestro 2 and Maestro 2E.
YMF7x4 Guide
Reply 11 of 13, by sprcorreia
I have the CD for my Videologic SonicStorm (ESS Maestro 1) and also for my Guillemot Maxi Studio ISIS (ESS Maestro 2E).
Maybe it has the driver you need. I'll check it later.
Reply 12 of 13, by ragefury32
cyclone3d wrote on 2021-09-16, 21:32:
You should be able to use the VxD/WDM drivers - from what I remember off the datasheet the only major difference between the 2 and the 2e is the sampling rate and some power saving feature.
Reply 13 of 13, by Yopachi
cyclone3d wrote on 2021-09-17, 15:15:
ess98.zip
Thanks for looking. I missed the notification here. I believe I've tried this driver as it's in my downloads folder. And no dice with the maestro 2e drivers so far. 🤷
