DOS Behaving Strangely
First post, by AppleSauce
I'm having issues with DOS 6.22 suddenly not responding to things like running edit or win from the main directory , I'm not sure what I've done ,
Maybe because I recently removed a mouse driver in windows 3.1?
Could that have messed some config files up?
Or could it be a hardware conflict?
Any suggestions would be appreciated.
Reply 1 of 2, by leileilol
SET PATH=C:\DOS\;C:\WINDOWS\
have this in your autoexec.bat
Reply 2 of 2, by AppleSauce
leileilol wrote on 2021-09-16, 03:09:
Thank You !
Since I recently upgraded some hardware and installed some new drivers and its been giving me nothing but grief.
It turns out I had the autoexec.bat misconfigured while I was mucking about and that the set path line was wrong.
So you were right on the money.
Thanks again.
