First post, by Kahenraz
I bought an MSI GeForce FX 5500 that appears to work but can also send the system into a BSOD. OpenGL works. Even the dxdiag DirectX tests work. But if I launch a benchmark or game that uses Direct3D like Unreal or 3DMark99, the system will crash.
I suspected that this was a counterfeit 5200 with a dodgy flash to a 5500 that only partially worked so I forced it to use those drivers and everything was stable. Interestingly, this didn't change the clock speeds so I'm not sure what changed within the driver.
I then removes the heatsink expecting to find a 5200 die but it is clearly etched as 5500. I have another FX 5500 by BFG which works fine when swapped in. I don't know what the deal is with this card.
Does anyone have any idea what's going on?
The attachment IMG_20210921_000649_resize_88.jpg is no longer available
The attachment IMG_20210921_000709_resize_69.jpg is no longer available
The attachment IMG_20210921_000808_resize_51.jpg is no longer available
The attachment IMG_20210921_000747_resize_75.jpg is no longer available
The attachment IMG_20210920_224630_resize_56.jpg is no longer available
Reply 1 of 1, by Kahenraz
I reinstalled the driver via Device Manager to FX 5500 to take a video and suddenly it's working fine. I uninstalled and reinstalled several driver versions prior to this without any change in stability which prompted me to create this topic.
I don't know what it's working now.
