First post, by tomcattech
What is the best App to use in Win98SE to get a good idea on how your card is performing?
Especially in general frame rate performance vs what is expected.
The current programs I am using are giving me a results that are meaningless because there is nothing to compare it to.
My card is currently a GeForce2 Ultra.
Thanks!
I either fix it or break it permanently... there is no try.
Reply 1 of 4, by leileilol
3DMark2001SE's a staple. It'll skip the nature, EMBM and pixel shader tests on your card but it'll provide enough results to compare on the result browser.
Reply 2 of 4, by tomcattech
Downloaded and Benchmarked.... I think something is wrong....
P3 Tualatin w/ 512 MB RAM
GeForce2 Ultra 64 MB
>>Score of 3268<<
High Res frame rates are disappointing.
Any ideas?
Drivers?
Something I noticed in looking at the specs within Win98:
$ffffffffff NVIDIA specific display adapter information
$ffffffffff ----------------------------------------------------------------
$0100000000 Graphics core : NV15 revision A4
$0100000001 Hardwired ID : 0152
$0100000002 Memory bus : 128-bit
$0100000003 Memory type : DDR (RAM configuration 0a)
$0100000004 Memory amount : 65536KB
>>>>>$0100000005 Core clock : 100.000MHz<<<<<
>>>>>$0100000006 Memory clock : 229.088MHz (458.176MHz effective)<<<<<
$0100000007 Reference clock : 14.318MHz
$0100000008 Maximum Fvco : 500.000MHz
>>>>>$0100000009 Core PLL Fvco : 250.014MHz<<<<<
>>>>>$010000000a Memory PLL Fvco : 458.176MHz<<<<<
Core clock for a GeForce2 Ultra should be 250MHz, but core clock says 100MHz (Rivatuner shows the same 100MHz)
What is this Core PLL Fvco at 250 MHz?
Any ideas?
Reply 4 of 4, by tomcattech
Figured it out.... multiple devices were on the same irq as the gpu. Fixed!
