First post, by Saturdaynight
Hi all! I'm having some difficulties getting my CH CombatStick 568 USB, to work in DOSBox. I'm running DosBox 6.1 in Linspire 4.5. The OS recognizes the controler but DOSBox does not! I read that DOSBox is suposed to simply recognize the controller without any issue's, so I'm guessing that this may not work. If there is no fix, what is the best Flight Stick to get for this setup?
