First post, by Chadti99
- Oldbie
Should it look like this 🤣? The aspect ratio seems right but it doesn’t fill the screen. I know I can adjust my CRT monitor settings but wasn’t sure. Nothing else I’m playing is this far off.
Yes, that happens to me too.
There´s a "RA setup.exe" or something like that (inside the game installation directory), that lets you choose between 640x400 (it starts like this when you first run it) and 640x480. The latter makes it look a little more accurate (but still it doesn´t fill the whole screen). I guess it has to do with our monitors (5:4 1280x1024 in my case).
Although now that I see your pictures better, it´s a proper 4:3 CRT in your case, right? Try the above If you haven´t yet.
By default it's 640x400x256@70hz, but has a 640x480x256@60hz fallback for certain Windows display drivers (laptops usually) that don't react well to a less than usual SVGA mode (despite well, technically being the same as the 320x200 double-scanned VGA mode)
My OG Red Alert CRT experience from the day looked somewhat like this simulated shader picture and i'm certain Westwood rolled with the off-squares in the UI. Pixel aspect ratio ignorance from the developer side was a very real thing.
