688 Attack Sub
First post, by Visceral
Attempting to start a new game after Mission Selection results in being kicked back to the command prompt with the message:
Fatal error number:50 File:Error writing to disk, possibly write protected.
The game is trying to create PROFILE.688 but can't for some reason. It's stored in a directory on my hard drive, which is obviously not write protected so that's not the problem. I have plenty of hard drive space available.
The problem is 100% reproducible. It happens every time, regardless of which mission I select.
I'm running DOSBox 0.63 under Windows XP/2GHz P4/1GB RAM.
Reply 1 of 1, by DosFreak
You said "which is obviously not wirte protected", did you actually check the directory for the "Read-Only attribute" and that the files within aren't set to "Read-Only"?
Make your games work offline
