First post, by appleg33k85
Good evening,
I'm trying to find a program that will work with my headland gc102 chipset, thus far I've tried using emm286, the last byte, himem.sys, & qram, none of them seem to work and programs don't see the extra available memory in my system. I've read this chipset has what seems to be bad support for memory management programs but i'm checking to see if anyone has any ideas that I can try out. Thank you for all the help, I've been learning quite a bit about these DOS systems!
The system is equipped with 2MB of memory
