First post, by Carles20vt
Hello guys,
I'm trying to rebuild my IBM PC/AT 5170, and now I'm trying to revive the original video card. It's an original IBM CGA adapter.
233.03 KiB
IBM CGA Video Card
When you plug it on the computer or any other system, it hangs it without doing anything. I put in a POST card to see what happens, but no code is shown.
I tried to see what line of the ISA bus hangs in the system. After some experimentation looking at the ISA bus pinouts, I found that the computers boot up if you cover all the data lines (D0 to D7).
I checked the CGA card diagrams fount at -0Cº but only saw a logic chip that handles these data lines to be Input or Output. I don't know how to test it or check the entire logic.
Of course, all the capacitors are checked, and none of them has been shorted. The ICs get warm after a while, and none of them is extremely hot at a touch.
¿Have anyone some idea what can I check and how? Or... if there is some list of typical issues (tantalum capacitors are one of them for sure).
I appreciate any help you can provide.
Reply 1 of 6, by mkarcher
Carles20vt wrote on 2021-10-12, 18:19:
That logic chip you talk about is U66, a 74LS245, a bidirectional data driver. Either that chip is broken, or it gets bad control signals, causing it to disturb ISA operation. As you said, the POST card doesn't output anything, so we can be very sure that the card disturbs the ISA bus even if it is not addressed. When the card is not addressed, pin 19 of U66 should be high, keeping the chip off the ISA bus. Even without a scope, you can put a multimeter on that pin. It needs to stay near 5V all the time, i.e. the value on the meter shouldn't drop at all, not even from 4.8V to 4.5V. If you hit the reset button, attempting a new POST, the pin still needs to stay at the same voltage. The CGA card is not addressed before the first POST code is issued. If pin 19 stays at 5V all the time, and the CGA card still disturbs the bus, U66 is broken. If pin 19 is low, you need to trace the logic generating that signal.
Reply 2 of 6, by Horun
Great detail mkarcher ! Curious if the Mono/Color switch was put in proper position for CGA.....not that being in wrong position would halt a boot AFAIK.....
Reply 3 of 6, by Carles20vt
mkarcher wrote on 2021-10-12, 18:38:
I had just tested it now and everytime is Hi (around 5v). So... I can assume that the IC is broken. I will order a new one and see what happens.
I tested a cheap CGA clone and I can see some small voltage decrements in some point.
Thanks a lot for the information! I will learn a little more about logics with this small finding 😁
Reply 4 of 6, by Carles20vt
Only a minor update.
I have just removed the U66 and prepared the board to install the replacement.
I removed the tape and tested it. The computer boots, and nothing happens. So, it is promising! 😁
630.43 KiB
608.7 KiB
Reply 5 of 6, by Carles20vt
The IC arrived at home sooner as expected. So I just installed it when I finished the work. (I can't wait a minute more). So I soldered it, put it on a test board (good known 386 board) with the POST card attached, and it started! Look at this!!! We have an image! And the POST card shows numbers, and the speaker counts the ram. It is promising.
321.21 KiB
So the IBM CGA was installed in his place, and then I was needed to set up using the Diagnostics Disk to set the "new" card. After that, I tested using the same tool to fine-tune the potentiometer on the mainboard to show the colours properly.
526.75 KiB
And after it, I tested (and played a little 😜 ) with these titles to test the card. Wow! CGA card indeed shows the games better-using composite! But the text is blurry. So, only games. OK, I can deal with it 😉
386.26 KiB
386.26 KiB
523.34 KiB
My dream is to have a CGA/EGA IBM monitor, but it is prohibitive to pay one, working or not.
So thanks a lot for helping with this topic. I learned a little from it. 😁
​​​​​​​Now I want to solve the last mystery that I have. The dead/crazy memory expansion board!
    385.77 KiB
Reply 6 of 6, by Horun
Good work !
