First post, by ThinkpadIL
My question is whether Serial-to-USB / Parallel-to-USB / SCSI-to-USB / PCMCIA (Type I or II) to USB adapters, that work under MS-DOS exist at all? And if yes, I'll be glad to know their names.
What I'm looking for actually, is a way to add USB port to old hardware with Serial/Parallel/SCSI/PCMCIA connections.
I've seen one image (see attached) with chain of adaptors that supposed to be a way to connect USB Disk-on-key to a Parallel port, but I really doubt that it isn't a joke.
    54.61 KiB
Reply 1 of 57, by cyclone3d
That pic is a joke.
The only thing really possible out of your list is a PCMCIA USB adapter. Those do exist but unsure if there are any that will work with DOS. Probably not with
There are some USB DOS drivers but you would just need to try them out and see if you can get something to work:
https://www.hiren.info/downloads/dos-files
http://academy.delmar.edu/Courses/ITNW1 ... rDOS).html
https://hddguru.com/software/2006.02.09-USBAS … -MS-DOS-Driver/
https://winworldpc.com/product/dos-usb-support/1x - this has some good info.
https://slomkowski.eu/retrocomputing/usb-mass … rage-on-ms-dos/ - this too
https://www.bootdisk.com/usb.htm
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 57, by ThinkpadIL
cyclone3d wrote on 2021-10-15, 13:46:
All PCMCIA to USB adapters I've seen were actually CardBus adapters, so they also won't work as I understand.
Reply 3 of 57, by cyclone3d
One thing does come to mind as far as parallel port goes.
You could always get a Microsolutions Backpack Parallel floppy drive and then replace the drive with a Gotek floppy emulator.
I guess you may also be able to do the same thing with a Parallel CD-ROM drive and one of those expensive CD-ROM emulators but you would be using an SD-Card if you went that way.
YMF7x4 Guide
Reply 4 of 57, by SScorpio
I'm not sure how far back you are looking to go, but PCI USB 2.0 cards can still be easily purchased. ISA was well before USB's time and I remember any cards coming out on that.
The question is, what are you attempting to do in DOS with USB?
If you are just looking to do easy file transfers, get a Gotek Floppy emulator if you can deal with the floppy size issues. Or get an SD2IDE and you can plug the SD card into a modern PC to transfer files and plug it back into your DOS machine, that won't be hot swappable.
Reply 5 of 57, by ThinkpadIL
cyclone3d wrote on 2021-10-15, 14:40:
Interesting idea. Though it seems like you'll be able to use only one type of device - Disk-on-key.
Reply 6 of 57, by cyclone3d
ThinkpadIL wrote on 2021-10-15, 18:36:
Yeah, but it would at least be hot swappable. You can fit a whole bunch of floppies on a single USB stick and you can switch between floppies.
YMF7x4 Guide
Reply 7 of 57, by ThinkpadIL
SScorpio wrote on 2021-10-15, 15:23:
I'm attempting to find a way to add USB port to HP 200LX ... and maybe to Toshiba Libretto 50CT too, though it is a Windows 95 machine, but still it isn't able to read CardBus type PC Cards as I know.
Reply 8 of 57, by BitWrangler
Halfway there...
https://www-user.tu-chemnitz.de/~heha/basteln … /lpt2usb.en.htm
Edit: though another way is to get a PCMCIA LAN adapter, then plug the USB drive into a USB capable router that mounts it as an SMB 1 share or FTP.
Reply 9 of 57, by ThinkpadIL
cyclone3d wrote on 2021-10-15, 18:43:
You are right, but as for storage solution, there is always PCMCIA ATA Flash cards (even via parallel port) and with normal USB port you are able to do much more thing.
Reply 10 of 57, by cyclone3d
Well.. here is a different idea. Parallel port to IDE adapter.. with DOS drivers.
https://www.ebay.com/itm/IDE-Drive-to-Paralle … 0-/273395273722 (Not my listing, nor do I sell these or have anything to do with the seller.)
  • IDE to Parallel Converter bridgeboard
    New in factory wrap
    Standard Datastor EP-2000 chipset
    DB-25 female and DB-25 male
    Daisy chain port for adding parallel devices
    DOS drivers included on 1.44 floppy
    Also works on linux (please check Linux documentation for compatibility and installation)
209.06 KiB
277.68 KiB
Microsolutions also made a parallel port external HDD back in the day. I have one, but have never used it. No idea what the max size the Microsolutions adapter supports.
YMF7x4 Guide
Reply 11 of 57, by ThinkpadIL
BitWrangler wrote on 2021-10-15, 18:54:
Halfway there...
Interesting homebrew solution, though as I understand it is intended to be used with USB Printers only.
Reply 12 of 57, by BitWrangler
It says it might later be developed for storage in the middle somewhere, so I guess the potential is there, just not the whole solution.
Reply 13 of 57, by ThinkpadIL
cyclone3d wrote on 2021-10-15, 19:09:
Well.. here is a different idea. Parallel port to IDE adapter.. with DOS drivers. […]
    New in factory wrap
Well, as for storage only I wouldn't be looking for enabling USB connection, since for Parallel Port and PCMCIA connections there are always available much more common devices like PCMCIA Hard Drives, PCMCIA ATA Flash Cards, CF Cards, and lots of storage devices you can attach to a Parallel Port (even SCSI devices via Parallel to SCSI adapter).
Reply 14 of 57, by cyclone3d
BitWrangler wrote on 2021-10-15, 19:13:
Page says it was last updated in 2018. 😐
YMF7x4 Guide
Reply 15 of 57, by cyclone3d
ThinkpadIL wrote on 2021-10-15, 19:16:
    New in factory wrap
Well, as for storage only I wouldn't be looking for enabling USB connection, since for Parallel Port and PCMCIA devices there are always much more common devices like PCMCIA Hard Drives, PCMCIA ATA Flash Cards, CF Cards, and lots of storage devices you can attach to a Parallel Port (even SCSI devices via Parallel to SCSI adapter).
What exactly are you looking to hook up via USB in DOS then? Are there DOS drivers for these USB devices you want to use?
YMF7x4 Guide
Reply 16 of 57, by ThinkpadIL
Yes, with homebrew solutions it is almost always like that - you may wait for years and in the end will get a half-way, half-working, half-solution that is in development forever.
Reply 17 of 57, by ThinkpadIL
cyclone3d wrote on 2021-10-15, 19:18:
Other than storage devices? Keyboard for example.
Reply 18 of 57, by Jo22
I've found some DOS drivers for USB mice years ago.
However, they do work with certain USB 1.x controllers and text-mode applications only, I'm afraid. 😨
Re: FreeDOS and Windows 98 SE - Dual boot and USB support
USB keyboard support is a bit tricky, because most developers/companirs assume
that the BIOS has a built-in emulation of PS/2 mouse/keyboard, anyway.
Reply 19 of 57, by ThinkpadIL
Jo22 wrote on 2021-10-15, 19:34:
I've found some DOS drivers for USB mice years ago. However, they do work with certain USB 1.x controllers and text-mode applica […]
Looks like there is no way to add a "regular" USB connection for hopeless devices like HP 200LX and for each purpose you have to find a specific way. 🙄
