First post, by retardware
I am thinking about a circuit to connect the PC speaker to my sound cards' line input.
The circuits I found on the forums are not applicable to my mobos' speaker circuit, because it does not have the "normal" open collector driver against 5V, but some different sort of amplifier.
So I am thinking about something like this:
file.php?mode=view&id=121797
The first (left in the schematic) pot serves to fine-align the RC filter which smoothens the digital edges of the speaker on/off switching.
The second (right in the schematic) pot serves to adjust the circuit output to a correct line level.
Now I wish I could use some PC speaker utility, with adjustable frequency selection, so I can do these alignments easily using the oscilloscope.
Does anybody know of such a program, ideally for DOS? Or maybe for Windows 95/98?
Edit: I guess the both 47R resistors should be made 470R at least... they are needed to limit the speaker amplifier output current... no idea yet which voltage levels it puts out.
    1.09 MiB
Reply 1 of 8, by weedeewee
https://jpsoft.com/help/beep.htm
I guess this will be what you're looking for
edit: nevermind windows software.
anyway, the 4DOS command.com replacement has a beep command that allows a different frequency to be specified. and there must be a tiny beep.com out there on the internet that does the same thing. :-p
edit : found something : https://ftp.zx.net.nz/pub/archive/simtel.net/ … usic/beep12.zip
Do not ask Why !
Reply 2 of 8, by Datadrainer
Hi.
Microsoft made a PC speaker driver for Windows 3.1 that convert PCM to squarewave frequency [https://winworldpc.com/product/pc-speaker-dri … iver-windows-31]
Knowing things is great. Understanding things is better. Creating things is even better.
Reply 3 of 8, by Tiido
You can also start QBASIC and use the SOUND command. "SOUND freq, duration" where freq gives closest possible freq to what you want and duration is how many 18.2Hz ticks the sound lasts.
Reply 4 of 8, by retardware
weedeewee wrote on 2021-10-16, 20:30:
Yes, this BEEP utility does just what I'd need!
But sadly it needs Windows XP at least.
Tiido wrote on 2021-10-16, 20:38:
Great!
This I can use even with DOS 😀
Problem solved 👍
Thank you very much guys 😀
Reply 5 of 8, by weedeewee
retardware wrote on 2021-10-16, 20:50:
No it doesn't. impossible even since it's a program from 1999 :-p
"Beep" is a small FREEWARE DOS utility which will beep at a specified frequency (in hertz) for a specified time (in milliseconds). It can be useful to use in a batch file to indicate an error, or even to make simple music 😀
unless you mean the jpsoft one, yes that was a google mistake of mine :-p
but you have what you need with the qbasic option, so, Enjoy ! 😀
Do not ask Why !
Reply 6 of 8, by retardware
weedeewee wrote on 2021-10-16, 20:56:
Sadly the old jpsoft version downloads page says Please note that these versions require a valid key to unlock them -- they are not freeware (except for TCC-RT and 4DOS), so not sure whether I can use them.
QBASIC is free, so it's the easiest way.
Thank you all again 😀
Reply 7 of 8, by weedeewee
retardware wrote on 2021-10-16, 21:04:
Sadly the old jpsoft version downloads page says Please note that these versions require a valid key to unlock them -- they are […]
I guess you missed the other link I posted :-p
Do not ask Why !
Reply 8 of 8, by retardware
oops, saw the edit now 😀
Guess I'll try this first, this saves me dealing with the QBASIC IDE (wurgs) for an one-liner 😀
Thank you again 👍
