First post, by dbo
Hello! New user here.
I got nostalgic after watching too many LGR videos and decided to put together a retro PC myself. Went to a local recycler and picked up the first late-90ish PC that POSTed. Upon closer examination it turned out to be quite a nice machine:
  • Asus P2B
  • Pentium II 300
  • 384MB RAM
  • Diamond Viper V330 / Riva 128
  • SoundBlaster AWE 64
  • Asus 40X CDROM
Didn't even need much cleanup, just a new CMOS battery! I'm planning to put Win 98SE on it and relive my late teen years.
It did not come with a HDD though, so I need some storage options. Thought about going with a CF-to-IDE adapter first, but decided to try spinning disks after all. I somehow wound up with 3 IDE HDDs (1x 20GB and 2x 40GB) - only plan to use one though. I managed to flash the BIOS to R1012 which should work with up to 120GB drives. However, it turns out the system really does not like HDDs. It's the same story with all three drives:
  • The BIOS "Detect IDE hard drives" screen finds the HDD with the correct size ...
  • ... but when booting I get "Master Hard Drive failure" (or something along those lines) during POST
  • I don't hear the drive spin up (though it could just be drowned out by all the other noise)
  • The master/slave jumper setting is correct (not that it would matter, the HDD is the only device on that IDE lane)
  • I tried different IDE cables, power connectors, etc.; including the same one that's on the CDROM, which (mostly) works
Interestingly, the CF-to-IDE adapter works without any issues! So it's not the IDE port/cable per se. Any ideas? The only things I could think of are: (1) all three drives are bad (which I find unlikely), or (2) the PSU is bad? I tried different power connectors, but to no avail. Also, the CDROM works (well, somewhat ... it works about half the time, the other half it just makes weird noises), and I doubt a HDD would need more power than a CDROM. I don't have another machine with IDE ports, so unfortunately I can't test the drives themselves. Any ideas?
I guess I can live with the CF adapter for now, but I'd really like to get an HDD working. Also, I'm really curious as to what the issue could be. Any advice is greatly appreciated!
Reply 2 of 10, by mR_Slug
dbo wrote on 2021-10-16, 23:45:
Hello! New user here. […]
...I'm really curious as to what the issue could be. Any advice is greatly appreciated!
Welcome.
You say the drive is detected in the bios correctly, This indicates it has powered up. I would try to verify this by taking it out of the computer and putting your ear against it. At any rate that error is not familiar to me. Can you post the exact message?
I'm assuming you are not trying to boot from a drive that has not been formatted and had the system files transferred to it.
The Retro Web | EISA .cfg Archive | Chip set Encyclopedia
Reply 3 of 10, by dbo
The "Auto-detect IDE Hard Disks" page in the BIOS seems to find the disk:
864.38 KiB
But when I reboot the POST fails with "Primary master hard disk fail / Press DEL to enter BIOS or F1 to continue":
427.55 KiB
I'm not anywhere near installing or booting an OS from it at that point, really seems to be a HW issue.
As for the PSU - I did open it to clean it, but I didn't see any obviously blown or bulging capacitors in there. There was some kind of weird waxy resin-like substance all over the place though, like dried glue. Not sure if that was supposed to be there or not, or where it came from.
Reply 5 of 10, by ODwilly
You could boot Puppy Linux off a CD-R and check the SMART data of the HDD.
Edit: Assuming the cdrom will read discs of course 🤣. Might want to find a cheap spare from Goodwill or your equivalent, its handy having a Puppy disk laying around and spare wifi/ ethernet cards for troubleshooting hardware.
Reply 6 of 10, by dormcat
Welcome! I'd guess the PCB on those HDD were still fine so the BIOS could detect their types and C/H/S correctly but their motor(s) of platters and/or heads might be faulty.
Most optical drives need up to 20W, while 3.5" HDD, even high performance 7200 rpm large (137 GB and more) ones, need no more than 10W. Most 2.5" HDD need only 5W.
Therefore if the CD-ROM works fine with the same Molex connector I wouldn't assume the problem is due to the PSU.
If you're interested into retro computing in a long term, PATA-to-USB adapters (a 40-pin adapter often comes with an additional power brick for Molex) will be very useful, allowing HDD and ODD to be tested or partitioned on modern computers.
Reply 7 of 10, by ODwilly
^ Solid advice. I might also add a bootable pci Sata card.
Using modern new SATA drives is really nice, and you bypass any weird issues with the integrated IDE. I have had some boards with just buggy IDE, so a Promise TX150 card ended up being the best option on my Dual Socket 370 P3 (Via).
It was $5 on Fleabay, and suddenly my 120gb HDD limit was gone and there wasn't anymore data corruption!
Reply 8 of 10, by weedeewee
While you can do a detect of the drive in the bios, can't you set the bios to just autodetect it on boot? If that's the way it's set and still doesn't boot, just ignore this. 😀
Do not ask Why !
Reply 9 of 10, by ODwilly
weedeewee wrote on 2021-10-17, 08:43:
Well he says it derects it, but has issues. Has a new bios, early CPU to rule out that issue. At least his CF cards seem stable.
Reply 10 of 10, by dbo
dormcat wrote on 2021-10-17, 03:25:
Thanks! Would be disappointing if all three disks are bad, but I guess you never know with these old things.
I see. Yeah, I'm hoping the PSU holds up 😃
Thanks, that's a good idea. I'll try one of those.
Interesting, I might give that a try as well. I have an old 2.5" SATA drive lying around that I could use.
Anyway, thanks all, that's giving me a few avenues to pursue. I'll keep you posted!
