First post, by DaCiRO
I have tried all the Aureal Vortex2 drivers in the vogons driver's library and found out that only the 2015 and the 2048 versions show the Digital/EQ tab in the Aureal control panel, the rest don't show this tab However they install the SPIF Detect and Enable option in the windows registry, but they are not enabled.
I want to get the hear the digital sound from this card, I dont have the MX25 sister card for the MX300 SPDIF, but I found out the find out from this guy https://www.dearhoney.idv.tw/SoundCard/Vortex … sing_cmedia.htm (is in chinese) and I confirm that it works, but only in WinXP, I can't get the digital sound in Win98, so I know that there is no issue with the connections, the cables or the HW in general. I am using a standard back panel S/PDIF bracket connected to the card to route the digital output to the speakers, like the one in the bottom picture
in Win98
The 2015 drivers; are ill of the PCI issue ("Vortex adapter not plugged into the primary PCI bus. joystick, modem and sound blaster emulation may not work on 2ndary PCI bus") that some users like me have on some MB (i.e.: mine is an Asus P4P800SE MB, Pentium4 processor, using Win98SE sp3). I tweaked the au30mmed.inf to disable bus detection but it doesn't work, the PCI issue still pops. The disable bus detection tweak works fine in other driver version of the drivers as far as I tested on 2031, 2035, 2041 and 2048, but not on 2015. If anyone knows different please share. It is a petty because this is the only version where all DIGITAL tab is enabled and working (with not greyed out options), but because of the PCI issue it w0n't install the SB16 emulation which is a MUST for me, so I have to discard the 2015 drivers for now.
The 2048 drivers; The PCI issue can be worked around by tweaking the au30mmed.inf prior the installation and it installs flawlessly, SB16 emulation enabled, it has the Digital/EQ tab in the Aureal control panel but all the options are greyed out (F*$k!). I checked the registry (regedit- Local machine/Software/Aureal/Vortex/AU8830/Customization) and notice that 'DetectSpdifOut' was set to zero '0' and also 'EnableSpdifOut' was set to zero '1', so that is the way the installation does it I guess.
I uninstalled, and prior installation in the au30mmed.inf file I set the 'DetectSpdifOut' was set to zero '1' , installed again,...but the same issue, in the registry 'DetectSpdifOut' was set to zero '0' again, it tried this ~10 times but same result, so this looks like an issue with the drivers and I can't change that.
To workaround this I created a registry file that set 'DetectSpdifOut' to '1', and this activates the Output Rate options in the Aureal Control panel (before this they were greyed out). I have to execute the registry change every time I boot as the registry change is not persistent, at least I do not know how to make it persistent. See picture below for the BEFORE and AFTER the manual registry change.
The problem is that I still do not get digital sound out in Win98 but this is no issue in WinXP (tried these with the VISTA drivers and it works, ...control panel does not work but digital sound is fine).
Any idea what else can I wo in Win98?. Also any points on how to make the Registry entry persistent would be great.
Reply 1 of 8, by DaCiRO
Bumping . checking if anyone was ever successfully getting SPDIF sound of a Aureal Vortex2 using the 2048 drivers
Reply 2 of 8, by ZanQuance
If you want proper S/PDIF support use the 2041 drivers with my 2041 S/PDIF tool, or the Montego II Quadzilla 2046 drivers.
For the 2046's you will need to mute the S/PDIF and then unmute it in the windows mixer control panel to get it outputting properly.
note: The fix tool will not work properly with the 2048 drivers
Hope this helps, and sorry for the belated reply.
[edit] Just realized Vogons doesn't have the 2046 drivers, so I'm attaching them here. I've removed the au30gm.arl to cut down on the size so it could be attached here.
During driver installation just point to the file included with the other drivers versions.
Reply 3 of 8, by kolderman
I have the MX300 and MX25 in a Win98 Machine. Don't recall the exact driver version -- but I do recall to get it working, I first installed the Diamond driver pack (to get the apps it comes with), then update the drivers through control panel to the latest ones from aureal. Since that, digital sound works fine.
Reply 5 of 8, by ZanQuance
Ah! Thanks for that cyclone3d, I didn't see that it also held the drivers as well.
I'll also leave my attachment for driver install brevity reasons if one doesn't wish to deal with a 300mb iso image.
Reply 6 of 8, by DaCiRO
ZanQuance wrote on 2021-10-21, 20:23:
Thanks ZanQuance, really appreciated.
I tried the 2041 SPDIF fix tool with the 2041 drivers but got no output, when I did that the Digital/EQ tab in the control panel was not enabled. I guess that for the 2041 SPDIF fix to work I need first to enable the Digital/EQ tab in the control panel (through a registry change) an then apply the fix?.
Reply 7 of 8, by ZanQuance
The tool writes a new VDB route into the card itself and hardwires the audio out the S/PDIF bypassing windows entirely.
If you're not getting any audio after using the tool then we should look into other things being the issue.
Reply 8 of 8, by DaCiRO
ZanQuance wrote on 2021-10-22, 12:21:
Got it, I understand now, thanks for the details on how it works, definitely something I need to check on my side. I had given up after days of testing different set ups, I took the MX300 out and replaced it with a SQ2500 which works perfectly, but I don’t like how the DB sits on it ( DB is longer that the SQ2500), and the fact that I really enjoyed the quality of the Headphone output of the MX300. However I have an MX25 coming on few weeks so I will re-start again with the 2041 drivers+ your SPDIF fox in the MX300+MX25 setup and will see how it goes.
