First post, by vinxi2
Hi everybody,
sorry for the dumb question. I'm trying to build a PC for Windows 98SE for the 95-2000 gaming era when 3dfx started to be.
I read that the easiest way is to get a P4 and I found a good deal for a HP DX2200 with a P4 3.0Ghz, 1GB of RAM and 80GB HDD. It comes with Windows XP.
Is it a good start? If not can you give me an advice of what to search?
If yes, can i replace the ATX and add a graphic card?
Thank you!
Reply 1 of 3, by zyga64
In my opinion - NO. Because of ATI PCIe chipset. Moreover - if you are planning to change motherboard later - this HP case has non-removable backplate.
Search for something from AGP era - Intel chipsets up to i875 (as well as VIA up to PT880) have native Windows 98 drivers.
You can pair it with Geforce 4 card - GF 4Ti is (of course) better performing, but for games from 95-2000 period GF4 MX440 will be sufficient.
Compatibility is just great, and you can use drivers as old as Detonators 4x.xx
For soundcard - SB Live! or Audigy.
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 2 of 3, by vinxi2
zyga64 wrote on 2021-10-22, 19:08:
Thank you.
Can you please name some motherboards or prebuilt PCs that I could search? I'm based in Europe.
Is it possibile to have microATX format?
I found a Micro Star MS-7042 with PT 800 and a Pentium 4 3.2 Ghz. Is it good?
Thanks
Reply 3 of 3, by zyga64
Yes, MS-7042 being socket 478 board with VIA chipset will be just fine.
You may also consider AMD platform (athlon64) - Socket 754 AGP VIA based motherboards.
