GL1zdA wrote on 2021-10-25, 12:42:Is there anybody who has drivers and/or manuals for the Siemens-Nixdorf (Fujitsu) Multimedia eXtension Board? This boards suppor […]
Is there anybody who has drivers and/or manuals for the Siemens-Nixdorf (Fujitsu) Multimedia eXtension Board? This boards support various inputs and operations, but also have the daughtercard that can do sound effects (Reverb, chorus, etc) on any source. I dug through several Siemens/Fujitsu pages (scenic.de, siemens-pc.de, fsc-pc.de, support.fujitsu-siemens.de, download.fujitsu-siemens.com, de.fujitsu.com) on archive.org, but found only part of the 32-bit Windows 9x driver. The files I'm looking for are:
MXB32_2.ZIP
MXB32_3.ZIP
MXB32_4.ZIP
MXB32PAT.ZIP
MXB32SA1.ZIP
MXB32SA2.ZIP
MXB16_1.ZIP
MXB16_2.ZIP
MXB16_3.ZIP
MXB16_4.ZIP
MXB16_SA.ZIP
MXBNTSP4.ZIP
MXBPTNT.ZIP
W98_MXB.ZIP
Interesting, as I have a very similar old Hauppauge card, but for the ISA bus - download/file.php?id=120561&mode=view
As you didn't mention them specifically, I had a root around on some of the archived Siemens-Nixdorf sites (mainly sni or mch.sni dot something) but with no success - just dead file links, product pages and reviews
https://web.archive.org/web/20000309002306/ht … er/zubehoer.htm
https://web.archive.org/web/19970203185231/ht … /news/mxb_e.htm
However, a general Google search proved more fruitful, especially some reverse searching based on the numerous linux driver posts (seems to have been a popular option with this card). This lead me to some archived sites where you can download nearly all the files you listed except MXB32PAT.ZIP, MXBNTSP4.ZIP & W98_MXB.ZIP (suspect these might be the various OS patch files mentioned in some of the following links)
Driver downloads - https://web.archive.org/web/*/http://www.schr … v/mxb/Treiber/*
Manual downloads - https://web.archive.org/web/*/http://www.schr … e/mxbtv/texte/* (I 've attached the most relevant below, but there are other MXB-related docs in there, so check!)
Other links
https://web.archive.org/web/20030411084820/ht … //www.mxbtv.de/ (file links here are dead but some others link to patch info & pics of various board accessories / cables etc)
https://web.archive.org/web/20030417022726/ht … aa7146/mxb.html
Finally, if you haven't seen them already, here are a few old ebay shots of the retail package
MXB manual, audio module manual & external connector pinouts
- Filename
- d971dt01.pdf
- File size
- 324.21 KiB
- Downloads
- 39 downloads
- File license
- Fair use/fair dealing exception
- Filename
- d984_mxb.pdf
- File size
- 85.2 KiB
- Downloads
- 38 downloads
- File license
- Filename
- belegung.pdf
- File size
- 40.27 KiB
- Downloads
- 37 downloads
- File license
Hope some of this helps 😀
