First post, by BuyBarvey
BuyBarvey
Offline
Hello,
I've been trying to get Windows 98 to work using DOSBox-X on a Raspberry Pi 4B - I've been amazed at the results so far! Previously there were so many errors on my system that it was unworkable but I now get a properly booted system. Hooray!
My main problem now is that the display appears very slowly. Opening My Computer takes a long time, and the window itself appears almost line-by-line. I've tried messing about with my .conf file (different outputs, etc) but nothing is changing - and changing the screen resolution in the conf doesn't appear to be changing the size of the screen either. My conf file:
[sdl]autolock=truefullscreen=truefullresolution=1280x720[dosbox]title=Windows 95memsize=512[video]vmemsize=8vesa modelist width limit=0vesa modelist height limit=0[dos]# Set 'ver=7.1' if using Win95 OSR2 (95B) or laterver=7.1hard drive data rate limit=0[cpu]cputype=pentium_mmxcore=dynamic_x86[sblaster]sbtype=sb16vibra[fdc, primary]int13fakev86io=true[ide, primary]int13fakeio=trueint13fakev86io=true[ide, secondary]int13fakeio=trueint13fakev86io=truecd-rom insertion delay=4000[render]aspect = true[autoexec]
Any pointers would be gratefully received - hopefully I've posted in the right place on the forum.
