First post, by appiah4
- l33t++
I am trying out a Terratec 128 ESS Solo-1 sound card on my K7VM2 mATX motherboard. The board has only 2 PCI slots and Slot 1 is inaccessable due to the VGA cooler. PCI 2 shares IRQ with the AGP and defaults to IRQ 10. I can not change this, apparently, because there is no Plug n Play OS option or IRQ reservation choices in the BIOS. It is VERY limited. I can't even force an ESCD reset. So ESS Solo-1 is stuck at IRQ10.
Now, when I load the DOS drivers for this in TDMA mode (I did not try DDMA, and I suspect that might also work on the KM266 chipset though would it be better?) it finds the card at IRQ10. Here is the funny part, if I set BLASTER to A220 I1 D5 T4, it just.. works? I tried Doom, and it worked at IRQ5. I tried Duke3D and it worked at IRQ5.
So my question is, am I misunderstanding how this thing works? Do the drivers, once loaded, start listening at the IRQ of the SET BLASTER parameter independently from the card's IRQ? Or is it just by chance that I got success with Doom and Duke3D?
