First post, by iraito
iraito
Offline
- Oldbie
I had to change monitor but now when win95 boots it tells me the GPU doesn't accept the new monitor and limits my graphic options and resolutions, if i boot without the VGA cable connected and then connect the VGA cables after the pc booted then everything works correctly, is there any way to make it so that win95 will not freak out with the new monitor at boot ?
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
