First post, by Brickpad
- Member
Hi guys,
I've got a Compaq Camaro SS7 board that I want to update the BIOS on to remove the original Compaq BIOS. From the information that I can find this board also the Mitac 5114VU and would like to "convert" it to non-OEM. Before I do so I'd like to know if anyone here has flashed the BIOS on this particular board using the Mitac image? And if so what problems you've run into in doing so? Thanks!
