First post, by RobDos
I have a ct4520 that does not detect the wave portion of the card.
There are two capacitors near what I think is the midi portion, see attached image. The capacitors are not bulged, but there is corrosion on the cap.
The card is a bit dirty, but I recall someone on here posting that a component frequently failed on some of these cards. The system I was testing it also did not have a -5V rail, but I checked the pin out and this card does not have a B5 pin so it's unlikely part of the issue assuming I read the diagram correctly.
What is typically the failure point on these units.
    674.9 KiB
P3 Slot 1 - 512MB PC100 - 128GB SSD - RADEON 9200 SE , SB Awe64 ISA - GOTEK MOD
Reply 1 of 7, by mockingbird
I have a CT4550 which no sound emanates from... It doesn't have the cap next to the memory IC but it does at the bottom left corner.
Mine's a Jamicon "SS" series, maybe I'll desolder it and measure it (it says 16V 10uF)... But it looks fine.
(Decommissioned:)
Reply 2 of 7, by RobDos
I had to use dos utils to get it to work, CTCM.EXE to configure the card in DOS then I had to load AWEUTIL.COM to get midi to work.
Depending on the game I had to provide different switches, and not always successful.
Reply 3 of 7, by RobDos
RobDos wrote on 2021-11-16, 02:21:
tried that, Failure setting MPU-401 at port 300H
Reply 4 of 7, by RobDos
Okay, so this is interesting and might be a clue
I use CTCU to configure the card.
I run diagnose, sometimes diagnose shows what I just configured in CTCU other times it shows different information
Sometimes it passes, sometimes it fails but I tend to not get midi output.
I'm wondering if it's fixable
Reply 5 of 7, by RobDos
Looks like replacing that one cap and redoing CTCU and fighting the auto config a few times got it working
the issue now is in the synthesized test i got a hung note /feed back
Maybe i should give up?
Reply 6 of 7, by Kamerat
Have you tried initializing the card with Unisound instead? It takes care of both PnP and Sound Blaster initialization.
YouTube channel
Reply 7 of 7, by RobDos
Kamerat wrote on 2021-11-17, 19:55:
Just did, seems to have no issues at all, Repaired! YAY another one saved from recycling!
