V30 Motherboard doesn't work
First post, by jmellidg
Hi people, I'm new in this foro, so please to meet you all. I'm not sure it it's the correct place to post this subject, but here we go...
I've recently bought a V30 pc, mounting in Spain by a company called INVES. The model is X30 plus. I can't put in a working condition, when I turn it on, a long beep follow by two short beeps tell me that the bios is working.
I don't have any information about the motherboard, so I can't fiddling with jumpers (very few) but I supposed that the error may be the graphic card or a memory error. I tested it with several graphics cards that work in other pc's with no change. I replace all the 640 KB chips, no change.
There is a little corrosion near the battery,
1.41 MiB
but it seems that doesn't affect the motherboard.
The -12v track to the isa slot was broken, but I fixed.
1.1 MiB
I'm running out of ideas, so I would be very grateful if you can help me.
The motherboard has 3 isa slots and a riser card. The chipset is from ACER. It's a 640 KB V30 powered. Lo and Hi bioses ( I find the bios for this motherboard but it's exactly the same that I have). It has support for floppy disk, XT-IDE hard drive, supports VGA graphic card and have a parallel and serial port.
I'll send you some photos of it.
1.99 MiB
Please if you have any information about the configuration of the motherboard or you know how to make it work, I would be very grateful.
Reply 2 of 22, by weedeewee
You didn't mention which graphics card you're using.
Could this be a mismatch between the jumpers and the videocard since XTs tend to have jumpers to select which videomode to be in use. MDA/CGA40/CGA80/EGA-VGA . maybe JP3&4 .
Do not ask Why !
Reply 3 of 22, by Anonymous Coward
This is a pretty unusual 8086 motherboard. I would guess it might have an Acer chipset, though not entirely sure because the branding has been blacked out. This is the first time I've seen this chipset. Normally the XT motherboards that have VLSI use single chip chipsets, but this one has four!?
It seems that "Inves" did not design the motherboard. Not sure whose logo that is. Mitac? Mylex? It doesn't appear to be on TH99.
This board has integrated HDD and FDD controllers. Do you know if it uses XTA or ATA?
Please dump the BIOS if you can. The BIOS chip appears to say "Mintek" so perhaps that's the company who really made the board.
Reply 4 of 22, by jmellidg
Hi, thank you for your help. I've removed the old battery and try to clean the most I can, but I didn't change the resistors and diodes. I think this is my next step. I can't seen all traces but all that I checked was Ok.
You're right, the chipset is from Acer, and uses XTA. I think that there was an Acer XT30 or something like this very similar.
I dump the bioses as soon as I can. Thank you for your help
Reply 6 of 22, by jmellidg
This is the original graphic card
1.51 MiB
And the bioses, there are Mintek
803.45 KiB
Reply 7 of 22, by jmellidg
Hi guys, I've removed all the corruption, and repair tracks broken. I had to remove the resistors and the diodes. I can't see anything in the diodes, do you guess what kind of diodes are???
Thank you!!!!
Reply 8 of 22, by weedeewee
D2 & D3 look like 1N4148
D1 ... could be a germanium diode.
be sure to put your multimeter on continuity testing and in diode mode to check those.
Do not ask Why !
Reply 10 of 22, by weedeewee
jmellidg wrote on 2021-11-17, 19:24:
D1 is broken... Doesn't survive.. Do you think it can be a germanium diode??
it kinda looks like a 1N60 diode
Do not ask Why !
Reply 11 of 22, by retardware
Welcome to the forum!
Awesome... an all-in-one XT board from the 486 era, even with onboard IDE...
That was the extreme budget range!
In a time when many computer stores had phased out 286 already...
Definitely a very special and unusual board!
weedeewee wrote on 2021-11-17, 22:40:
Could well be possible!
But, I don't think that this battery discharge protector is relevant for the bus not working.
Is it only a photo artifact, or is there some trace cut (and maybe even short) around bus line ~25 between the two rightmost slots??
Reply 12 of 22, by weedeewee
This https://hwmuseum.pp.ua/motherboard/1784 ... 19]=3x8bit looks to be a very similar motherboard aside from the color
also has a bios available.
INVESTRONICA 8086 XT-plus
Do not ask Why !
Reply 14 of 22, by jmellidg
Hi! Thank you for your answers, yes retardware, this trace is cut, I identified with the -12 track and is repaired. With respect to the Russian site, I think that if its not the same is very very close!!. I'm going to buy this morning the components and try to fix all the cut traces and try to upload a picture of the back thanks!!
By the way, how can I upload the bioses, with what extension to be allowed??
Reply 16 of 22, by jmellidg
Hi everybody! After repair 12 cutted traces and change resistors and diodes, my baby work for the first time!! Thank you very very much for your help. I'm going to upload the bioses if it can somebody help.
Thank you!!
Bios_8086.zip
42.31 KiB
44 downloads
Reply 19 of 22, by Anonymous Coward
I'm really curious what's in those BIOS chips. The board is using two 256kbit EPROMs, which seems like a lot for an XT.
