First post, by kolderman
I though I would try out an Athlon XP-M cpu I have had lying around for a while. The main interest in how slow it can go using setmul.
However, when I try and use setmul to change the multiplier, the system locks up. Setmul detects it as a K7 at the correct current mult/freq.
Is it supposed to work?
Reply 1 of 12, by BitWrangler
What motherboard/chipset/bios version ??
Reply 2 of 12, by luk1999
What motherboard do you use? Have you tried another apps to set multiplier (eg wcpuid)?
Pentium 4 2.4C, ASUS P4C800-E Deluxe, 1 GB RAM, GF FX5700 128 MB AGP, SB Audigy, Chieftec GPS-400AA-101A, Win XP SP2
Celeron 400, Compaq Garry, 128 MB RAM, Voodoo Banshee, ALS100 Plus+, Compaq 200 W, Win 98SE
Reply 4 of 12, by BitWrangler
According to a page on fab51, which I can only get at with googles cache at the moment, (horrendous url alert) ...
http://webcache.googleusercontent.com/search? … n&ct=clnk&gl=ca
That board has been confirmed to work but boots at maximum mobile multiplier. A genuine mobile chip has it's max multi pegged at it's rated speed and it locked from going higher, whereas a mobile modded desktop chip may have it floating at 24x so this board might have problems booting one unless it had it's mobile multi capped.
So the question is, were you trying to set a higher multi? (unpossible) or a lower one? (shoulda oughta worked)
Reply 6 of 12, by BitWrangler
Hmm I don't know if I've seen ppl set them lower than 5 or 6, but not sure if that's a hard limit on the CPU or just because motherboards/chipsets never expected to see any athlon or duron slower than 550 or 600 Mhz.
Reply 7 of 12, by kolderman
The mobo is revision 2, the bios is W6378MS V1.8 121801. There are not rev2 bios updates on the MSI website, just pbi 3.1.
I tried going to 5x, same problem. This is where it locks up (image). I will try wcpuid. Are there other tools besides?
    1.91 MiB
Reply 9 of 12, by BitWrangler
There's another oldie that might work on windows, https://www.majorgeeks.com/files/details/gcpuid.html
Reply 11 of 12, by luk1999
BIOS probably doesn't support Mobile Athlons.
If you have another motherboard (preferably something with VIA KT400/600 or SiS 746/748, ASRock is a good choice for playing with mobile CPUs) then you can test your XP-M on it.
