First post, by jmellidg
Hi guys,
I'm looking for a 386dx motherboard BIOS with the following string
30-0200-001453-00101111-111192-mxic-h
I think that the motherboard model is - Informtech IT-AM33/40-DLC
I've found information about it but no the bios. If you have one or you know where I can find it, please tell me I will be very grateful
Thank you very much!!
Reply 1 of 13, by Thermalwrong
Hmm, can you show a picture of it? I think I have one, it looks like this:
1.12 MiB
I can pull it out and get a copy of the BIOS, it looks like I don't have that saved yet. Then I'll probably put it into the 386 bios thread too
Reply 2 of 13, by jmellidg
Hello!!! Yes I've bought just a few days ago. It seems that there's no 8742 and no bios, so if you are so so kind to make me a copy of the bios and the 8742 bios I will be very happy and I need to invite you a beer if you come to Spain!!
124.73 KiB
Reply 3 of 13, by weedeewee
that 8742 isn't a rom, it's a microcontroller, programmed to handle the keyboard interface..
Do not ask Why !
Reply 4 of 13, by Deksor
According to here, the actual brand is kaimei. (manufacturer code is 1453)
https://www.ultimateretro.net/en/bios/infoadv
Reply 7 of 13, by Deksor
It's a microcontroller with some program to turn it into a keyboard controller. I don't think these have been property reverse engineered yet. However they're usually exchangeable.
Reply 9 of 13, by quicknick
For a quick test I guess it would be ok to use a BIOS from another board with the same chipset.
Let's say, Octek Jaguar V, which you can find here
Or the more obscure TAM/33/40-MA0 from here
Keyboard controllers are usually interchangeable, so you might borrow one from another motherboard.
Reply 10 of 13, by Thermalwrong
Okay, dug it out from its usual home and pulled the BIOS chip. It's quite tightly integrated since it's a baby-AT board in a micro ATX case.
Anyways, here's the BIOS ROM, along with a picture showing which ROM chip it is. I'll get this into the 386 bios thread too.
396.06 KiB
Reply 12 of 13, by Horun
Found this board to be very near exact (same real pics) except the location of Jp2 and Jp4 are swapped AND the clock jumpers are a bit diff in th MH picture
https://www.ultimateretro.net/en/motherboards/3103
Also the page lists JP3 but the MH image does not show it. But those errors are common in many of the old MH/TH99 pictures.
