First post, by jamie175313
Currently trying everything i can with this to increase the fps and get better compatibility with directx8 for windows 10
This is what it currently does. Any type of Character or Monster that is in the game this is there texture and unsure of how to fix this.
attachment%5D
Reply 1 of 4, by jamie175313
Anyone know how to fix the Texture Tearing in this ? i've tried multiple settings with voodoo2
Reply 2 of 4, by mrpenguinb
jamie175313 wrote on 2021-11-26, 03:54:
Try setting the GPU in the DirectX tab to the GeForce FX Ultra.
What GPU/chipset/card/adaptor does your computer have? The video cards in dgVoodoo2 are emulated, you don't need to match dgVoodoo2 to your actual GPU.
Reply 3 of 4, by Garrett W
I thought the OP were trying to use an actual Voodoo2 for a moment there.
Perhaps it would be helpful if you let us know which game you're trying to play; Perhaps someone else has already figured out a way to do so.
Reply 4 of 4, by darry
Garrett W wrote on 2021-11-29, 10:42:
That and the Voodoo 2 is 1998 era hardware. By 2004, its relatively small max texture size, lack of Direct7+ features and performance were unlikely to make playing many then new games particularly pleasant, even when possible through hacks or workarounds .
That said, not all games require the latest and greatest hardware, so if your game isn't too demanding, it may well be possible to make it work well on your Voodoo 2 .
Doh, I misread . It's not an actual Voodoo 2 . Sorry .
