First post, by Kahenraz
I have a motherboard with a soldered BIOS chip that I wanted to socket for hot flashing. I have never replaced a chip like this and it's in a location with a lot of surrounding components so I spent a lot of time planning on how to approach this.
1.25 MiB
I did a lot of tests and experimentation on a parts board with different iron settings and a hot air station for both removing the chip and adding a socket. Removing SMD components, even as large as this, is easy to do with a hot air station but I didn't want to risk melting any of the adjacent plastic parts so I opted for an alternative.
553.07 KiB
This is ChipQuik's SMD removal kit. It includes a small tube of tacky flux and a very low melting point solder. When this is mixed with the solder on the board it allows a generous amount of time to heat all sides of the chip while remaining molten. This is extremely gentle on the part itself and the effect is like magic. Chips just don't float off of a PCB but they do with this stuff. There are videos of it and they are absolutely real. There is a lot of cleanup involved but this can be managed with a solder braid.
Here is what the board looks like with the chip removed.
1.15 MiB
And the chip itself after being cleaned and washed.
374.81 KiB
506.22 KiB
Reply 1 of 9, by Kahenraz
I had initially thought that I could add a socket with some solder paste and a hot air station but testing this on a parts board showed that the socket itself would start to melt before the paste had a chance to become molten. While technically possible, the socket itself is easily damaged. It's also very difficult to know if all of the solder paste has melted if any of it gets under the socket.
I found a guide on YouTube that showed that it is possible to hand-solder each pin if the plastic center of the socket is removed. This is the method I ended up using and, while tedious and difficult to maneuver, is safe and does not risk damaging any of the neighboring components.
I held the socket in place with some mounting putty and then it was just some careful soldering one pin at a time. This can be very awkward because the board must be rotated for each side.
825.96 KiB
Although I don't think this is necessary, I put the little plastic center back into place with some double-sided tape. The shape suggests that it prevents the chip from falling into the socket but it didn't seem to sit any deeper with or without it.
899.93 KiB
Here is the modification completed.
694.78 KiB
898.7 KiB
Reply 2 of 9, by Kahenraz
I just noticed that I put the plastic bit in backwards. The arrow is supposed to point towards the notch but since the chip can't be inserted backwards anyways, it's only a cosmetic flaw that no one will see but I will know and it will haunt me forever excuse me I have to fix this right now... 😮
Reply 6 of 9, by Kahenraz
I was watching a video on YouTube and saw someone use a PLCC socket with a grid arrangement instead of a diagonal one for the support frame on the bottom. This one looks to be designed with hand soldering in mind unlike the diagonal one which is probably meant for wave soldering.
319.1 KiB
Reply 7 of 9, by Sphere478
Nice job!
Sphere's PCB projects.
