First post, by Kahenraz
A motherboard I ordered from eBay come with a damaged trace (among other surprises).
1017.67 KiB
There were several possible approaches to this. What I ended up doing was folding back the copper traces and soldering a resistor lead that I had cut to size as a brace and flow solder over the entirety to secure it in place.
I considered cutting the trace and running a thin piece of wire but I felt that if the lifted trace could be made to stay flat beneath a bit of lead then it would have a larger surface area to bond to and be stronger overall. If this didn't work then I could always cut the traces and run a wire later.
This ended up working fine and the repair is very sturdy. I did have to flatten the lead in my pliers first to keep it from rolling away.
538.66 KiB
Here is a close up before and after I applied a bit of kapton tape to add a bit of extra protection.
1.07 MiB
1.52 MiB
The finished repair zoomed out for scale.
720.07 KiB
Reply 2 of 4, by jbenam
I often do this as well - works pretty well. Cut resistor legs are very useful, I tend to save them for repair jobs like this 😀
For thinner tracks I usually use kynar wire in the same fashion. Looks pretty snazzy and unless you are looking at it intently, you can't even notice it.
Reply 4 of 4, by Kahenraz
This trace is actually pretty wide. For thinner traces I've had to use strands of solder wick which are surprisingly perfect for fine pitch repair.
33.15 KiB
72.45 KiB
304.25 KiB
Intel Slot 1 slocket troubleshooting and repair
I don't like using wire wrap because it's difficult to scrape off the enamel on either end to solder to it.
