First post, by Digidreamer
hi,
back in the day..... it was possible to alter the ramdrive the CD bootloaded so you could add extra drivers autoexec etc., (In my case USB Support) think it was referred to as slipstreaming, but can't remember how, but I do remember having to modify a virtual image file then edit/burn a new ISO of the windows install disk.
want to include USBASPI and rewrite the sys and autoexec so then can run the windows setup like on a IDE based pc all from one disk. make it simplicity itself.
do I copy it into the EBb.cab or the Dos folder on the CD, and edit the Config.sys and Autoexec.bat
need a refresher, anyone out there of has this knowledge been lost??
I Like Charity Shops, they're like steam and GOG but cheaper.
Windows 98se - Wyse V10LE 1.2Ghz, 1 Gb, 16Gb SSD
Windows 98se - Compaq Evo 550d SSF, P4 2Ghz, 1Gb, 60Gb(Partitioned)
Dos 6.2 - HP7510 512Mb, 4Gb
Reply 1 of 1, by Digidreamer
Ok, can't find the EBD.CAB, closest I can find is fat32ebd, not sure if this is the one the CD uses to boot from?
